snupa Posted October 5, 2012 Posted October 5, 2012 I am trying to reinstall Autocad 2011 but the program says that it is already installed. I've tried the fix for a 'Clean Uninstall' from the Autodesk site but it does not work for 2011. Somewhere there is a hidden file or entry that the installing procedure looks at. Are there any gurus out there that can shed some light on 2011. thanks Quote
ReMark Posted October 5, 2012 Posted October 5, 2012 There is no need for multiple threads on the same subject. You may have overlooked something. Aren't there a couple of folders that have to be cleaned out manually? Did you shut down your computer then reboot after you did the uninstall? Quote
Dana W Posted October 6, 2012 Posted October 6, 2012 I am trying to reinstall Autocad 2011 but the program says that it is already installed.I've tried the fix for a 'Clean Uninstall' from the Autodesk site but it does not work for 2011. Somewhere there is a hidden file or entry that the installing procedure looks at. Are there any gurus out there that can shed some light on 2011. thanks This is a word for word copy & paste of the original post from more than two years ago. What's up with that? I have seen odd things before, but the bar is a little higher now. Quote
SLW210 Posted October 8, 2012 Posted October 8, 2012 My guess is it is a spammer. We will wait and see. Quote
Gurpreet Sachdeva Posted December 4, 2019 Posted December 4, 2019 If I want a bulk uninstall in my organization and I want to use batch file then what to do I tried these solution to uninstall but didn't work msiexec.exe/Uninstall{5783F2D7-9001-0409-0102-0060B0CE6BBA}/quiet /norestart msiexec.exe/Uninstall{5783F2D7-9001-0409-1102-0060B0CE6BBA}/quiet /norestart. msiexec.exe /x{5783F2D7-9001-0409-0102-0060B0CE6BBA}/quiet msiexec.exe /x{5783F2D7-9001-0409-1102-0060B0CE6BBA}/quiet msiexec.exe /x{5783F2D7-9001-0409-0102-0060B0CE6BBA} msiexec.exe /x{5783F2D7-9001-0409-1102-0060B0CE6BBA} Quote
