jen-s Posted August 3, 2010 Posted August 3, 2010 While trying to plot in AutoCAD LT 2009, when I select our PDF plotter (a .pc3 file) in the pulldown, AutoCAD immediately closes. (Side note - never had this problem in pervious version AutoCAD LT 2006; and only my computer, others in office work great). Any Ideas? Quote
mdbdesign Posted August 3, 2010 Posted August 3, 2010 Do you have all fixes and updates installed? Quote
jen-s Posted August 3, 2010 Author Posted August 3, 2010 I just installed the maintainence update - now I get this message: FATAL ERROR: Unhandled Access Voilation Reading 0x448d533c Exception at 7c910f1eh Then it closed down. Quote
mdbdesign Posted August 3, 2010 Posted August 3, 2010 So now you know what is wrong. Suggest go to Autodesk and search within Knowledge Base for this error. Hope it will get you solution. But you can use program for anything else? Do you try cad to pdf Autocad internal printer? Quote
iskalipsi Posted August 4, 2010 Posted August 4, 2010 Try to add a new PDF plotter.Go to Options>plot and publish tab> add or configure plotters. Try to add a new PDF plotter name then try to plot from that plotter name and see if it still has that error. Quote
jen-s Posted August 4, 2010 Author Posted August 4, 2010 -The knowledge base support has no info. -I have tried several times to add another plotter with no success - program still closes down. What is puzzling is that I am am to use this pdf printer in other programs, but not AutoCADLT2009 or Trueview. Others in my office can use this same pdf printer with success in AutoCAD. I have checked my settings to see if that match others and they do. Quote
mdbdesign Posted August 4, 2010 Posted August 4, 2010 What printer you use? Did you can print to any other than PDF printer? Quote
jen-s Posted August 4, 2010 Author Posted August 4, 2010 I can print useing other system printers and .pc3 files from AutoCAD. I am trying to use AllPDF printer from BCL Technologies. (Which others are currently useing with AutoCADLT2009). Quote
mdbdesign Posted August 4, 2010 Posted August 4, 2010 Try cutePDF or Bullzip it is free and you need to try as below: Quote
jen-s Posted August 4, 2010 Author Posted August 4, 2010 Installing CutePDF worked! Thanks for the solution - I appreciate the help! Quote
