Is there a way to grab the name of the file you are working on, and store it as a variable??
eg.
You open a file called 'square', and you want to take the drawing name and store it as variable 'name'.....
Not sure if this can be done, but if it is possible, the answer would be found on this forum for sure.
Kenter
It can certainly be done. Type the following code into the command line.
(setq name (getvar "DWGNAME"))
Afterwhich type: !name on the command line.
Also, (getvar 'dwgprefix) will give you the location.
Thank you both. I used:
(setq name (substr (getvar 'dwgname) 1 (- (strlen (getvar 'dwgname)) 4)))
It grabbed it without taking the .dwg at the end.
Kenter
or
(vl-filename-base (getvar 'dwgname))
Kenter
Really a very smart result . :thumbsup: you do have the ability to get through codes.
Best regards
Tharwat
or
Undoubtly , this is the shortest and direct one ..... :thumbsup:
faster too
Unnecessary, but for the VL-phobic:
(substr (getvar 'DWGNAME) 1 (- (strlen (getvar 'DWGNAME)) 4))
Or
(cadr (fnsplitl (getvar 'DWGNAME)))
(cadr ([color=red]fnsplitl[/color] (getvar 'DWGNAME)))
Lee you are a dictionary of undocumented lisp functions! :D
lee you are a dictionary of undocumented lisp functions! :D
