  • Replies 28
  • ReMark
    12
  • JD Mather
    7
  • faarax
    7
  • Patrick Hughes
    2
Posted Images
Would you have a pasion to look this.
Thank you
  Quote
.... which I mostly fixed after you suggesting
How much were you permitted (required?) to change on the original model or was it supposed to be exact?
Your model doesn't look very much like original?
The hole does not go through the large cylinder.
The small cylinder is just resting on the bracked and will require welding (no fillets shown as on drawing).
Small cylinder is skewed.
Angle is not tangent.
Angle of slot is not parallel with edge.
Support rib missing.
Fillets missing in triangular slot.
Fillets missing in rectangular slot.
Rectangular slot is in wrong location.
8mm holes are in wrong location (should be 45 not 40 from edge).
R15 arc is in wrong location.
I might grade something like this at about 5/100 (not good).
Edited by JD Mather
Thank you
Are you talking to me?
I'll take a look at it shortly but from what JDM posted above I can already say I'm very much likely to agree with him 100%.
How much training have you had using AutoCAD 3D commands?
faarax: You, literally, have to go back to the drawing board. Your 3D model needs further work. Perhaps you would have benefitted from our input had you taken the time to ask questions. While we won't do the work for you we would be more than willing to share our knowledge and make suggestions that will help advance your skills. That's what we're here for. You have wasted a valuable resource.
What else do you have for us to view in the meantime?
Edited by ReMark
Are you really interested in learning how to model this part?
I could walk you through the steps - but it would require two-way communication. (In otherwords you would have to actively participate in this discussion.)
faarax: JDM's generous offer should not be turned down. I'd take him up on it if I were you.
Dear JD Mather,
I do appreciate for your generous offer, and I happy to take advantage of it.
I have redone the Bracket, and this time I believe it is close to march the original drawing, thanks for JD Mather and Remark.
Since I have limited training about 3D modeling, I have a more complicated drawing which will help me understand more about 3D modeling. I am going to attach the second drawing( a Piston) into this massage and old drawing also soon .
Thank you so much!
Looks like a challenging project. Good luck.
Pick something easier - this part is too hard for a beginner. Trust me.
