Import page setup information automatically
hosannabizarre
Currently I use a lisp file to import page setup information, which brings
in previously configured plot set up information (as found in a specified drawing template).
page_setups.lsp...
(DEFUN C:PSN () (command "._-PSETUPIN" "W:/Library/Acad Setup/Page_Setup_Template/page_setup_template.dwg" "*"))
Although I have "page_setups.lsp" identified in my startup suite of
applications to load, I still have to type "PSN" to import page setup info.
Typing these three letters is tiring my fingers out.
Can I build the import instruction into accaddoc.lsp so that
I don't have to keep typing PSN, so that it autoloads (and imports)
with every session / drawing??
Cheeeeeeeeeers,
hosannabizarre
Yes , Actually this is the way of lots of experts in programing.
Try it ...... although I haven't tried it before
Regards,
Tharwat
Thanks tharwat313
The thing is, I'm not sure where to put it in the existing code.
My accaddoc.lsp is as follows:
;;;*-*TXT acad.lsp is loaded once, acaddoc.lsp is loaded for each
;;;       document, s::startup in any case is called after acaddoc.lsp
;;;       has been loaded
;;(if (= nil acad_helpdlg)
;; (progn
;;    (load "acadr15.lsp")
;;    (load (strcat (getvar "menuname") ".mnl"))
(if (= nil genlade)
   (princ (load "gen/acadm.lsp" "\nError: acadm.lsp not loaded!"))
   (if acadmappend (setq s::startup (acadmappend s::startup)))
Can someone please identify where, in the above code, I would locate the instruction to import the page setups from my template?
i.e Where would I put this...
I tried adding it to the end but it didn't seem to work.
Thanks
You can put it anywhere, as lon as it's outside a DEFUN statement autocad will parse it.
I'm not sure that that meathod would be great technique though!
  • 3 weeks later...
I have realised that the method outlined here is better.
i.e. make a button which invokes a lisp like this:
(defun c:plot40 nil
(vl-load-com)
(command "_.-plot" "yes" "" "\\\\Kwifs1\\KWIN_40" "A3" "Millimeters" "LANDSCAPE" "NO" "Extents" "FIT" "CENTER" "YES" "KWIN40.ctb" "YES" "W" "NO" "NO" "yes" )
