MSasu Posted August 2, 2010 Posted August 2, 2010 pryzmm said: msasu - thanks a millionnnnnnnnnnnnnnnnnnnnnnnnn !!! You're welcome! Regards, Quote
pryzmm Posted August 21, 2010 Author Posted August 21, 2010 hi again guys, i do not want to start another thread so i dig up my old one that is where it all started. msasu had compile an excellent routine (see below) i have tested it several times in acad 2008 and 2009 (arch't) in a totally clean drawing environment (no drawing at all except the p-line i was testing the routine with) which execute perfectly, everything is smooth. then i have added a few lines of code just to use my preferred "layer" in doing the wipeout, and when i tested it at my office work (messy drawings - cad 2009),, it just went through up to the end of the routine without any thing done, no errors too,,,, im sure there must be something in the code that i messed up,, could anyone take a look,, im not too familiar with lisp just yet. appreciate any help code start here;;; ; ;created by: msasu 31-08-2010 ;lwpolyline to wipeout routine ; ; (defun c:PL2WO ( / OldOsmode MyPline NrNodes Param1st Param2nd ParamLen DefameSize theCounter ) (vl-load-com) (setq OldOsmode (getvar "OSMODE")) ;;-- (setq oldlayer (getvar "clayer")) ;;-- (if (and (setq MyPline (car (entsel "\nSelect polyline: "))) (setq NrNodes (getint "\nNumber of vertexes: "))) (progn (setq MyPline (vlax-ename->vla-object MyPline)) (setq Param1st (vlax-curve-getStartParam MyPline) ;parameter at start point Param2nd (vlax-curve-getEndParam MyPline) ;parameter at end point ParamLen (- Param2nd Param1st) ;parametrical "length" DefameSize (/ ParamLen NrNodes)) ;size of defame (setq theCounter 0) (setvar "OSMODE" 0) (command "_PLINE") (repeat NrNodes (command (setq thePoint (vlax-curve-getPointAtParam MyPline (+ Param1st (* theCounter DefameSize))))) (setq theCounter (1+ theCounter)) ) (command "_Close") ;------------------------------- added code (if (tblsearch "layer" "SF_FP-WIPEOUT") (command ".-layer" "set" "SF_FP-WIPEOUT" "") (progn (setq rgn (getvar "regenmode")) (setvar "regenmode"0) ;;-- (command ".-layer" "make" "SF_FP-WIPEOUT" "color" "254" "ltype" "m-dot" "" "") (setvar "regenmode" rgn) );progn );if ;------------------------------- end of added code (command "_WIPEOUT" "_P" (entlast) "_Y") ;restore orig variables ;;-- (setvar "clayer" oldlayer) ;;-- (setvar "OSMODE" OldOsmode) ) ) (princ) ) ;;; also if you guys need to know the full story behind this lisp pls. feel free to read page 1,2-->> thxxx Quote
