Chanell DP Posted September 8, 2008 Posted September 8, 2008 I need a quicker way to identify the co-ordinates of the stormwater system. Preferably as a list which I can then import into Excel. We working on the WG27 co-ordinate system imported from Model Maker. Your help will be greatly appreciated. I need a quicker way to identify the co-ordinates of the stormwater system. Preferably as a list which I can then import into Excel. We working on the WG27 co-ordinate system imported from Model Maker. Your help will be greatly appreciated. Quote
Cad64 Posted September 8, 2008 Posted September 8, 2008 Is this a 3DS Max question or a Civil 3D question? Quote
Cad64 Posted September 8, 2008 Posted September 8, 2008 I've moved your question to the "Map 3D" section. Quote
GE13579 Posted September 8, 2008 Posted September 8, 2008 If you type LIST and select everything you want it will give you all coords, but as far as exporting to Excel, other than copying and pasting I don't know I'm afraid. Quote
fuccaro Posted September 8, 2008 Posted September 8, 2008 Cad64 said: I've moved your question to the "Map 3D" section.... and I moved here the thread from the Beginner's Area. It is enough to have a question asked once in the forum. Quote
rustysilo Posted September 8, 2008 Posted September 8, 2008 Is your stormwater system composed of Civil 3D objects or regular AutoCAD objects? If Civil 3D objects then I don't believe Map will be able to extract that information. If AutoCAD objects then you can perform a Map query on the objects to get the data you need (provided that your objects are blocks or are layered separately from other objects). Quote
