woutervddn Posted July 25, 2010 Share Posted July 25, 2010 hi, I'm working on a program that should make some work at the office run autonomous. People will be able to ask for drawings and get a general idea of the price of their product. To let it all go automatic I used the AutoEdit() command. So when I now open the drawing it updates everything makes the drawing fit the screen, pauses the program (so the drawing has time to adjust), and prints it as a pdf. so after the update this is the code: 'change zoom ThisApplication.ActiveView.Fit 'pause the program Dim Finish As Single Finish = Timer + 5 DoEvents Do Until Timer >= Finish Loop 'create pdf ThisDocument.PrintManager.SubmitPrint The programs runs great and everything works. BUT, since everything must go automatically I don't want to press the drawing. when user click send on the online form the drawing must do everything by itself. To do so I've made a VB program which does this: 'open inventor Dim InvTmp As Inventor.Application InvTmp = CType(CreateObject("Inventor.Application"), Inventor.Application) 'open the document InvTmp.Documents.Open("C:\Users\Wouter\Desktop\T&A\My Dropbox\knowledge base\Fase 3\html to inventor\nozzle.ipt", True) And for some reason this goes wrong. when the document is open and starts the AutoEdit(), VBA tells me that Timer has an runtime-6 error overflow. I can't find the source of this. everthing works when I click the drawing but I can't get it automated because of this. I can't drop the pause cause else the zoom wouldn't be changed by the time the printing starts (with a half drawing as a result) any ideas about how to fix this? Quote Link to comment Share on other sites More sharing options...
