I wanted this a long time but I wasn't ready to make it.
But BAM here it is, it is a pretty simple code after I found the random number generator.
What it does:
Asks for a selection takes the solids and give them a random color!
Pretty handy to get a decent overview. I posted the whole code, there is some copyright nonsens on the random code but if I don't place it here every-one knows that site: http://cat2.mit.edu/4.207/tutorials/alisp/random_01/random_01.html will go down some day and all will be lost.
Type RCS to use it
;; Function made by Marijn van den Heuvel
;; you can change the 10 160 to get different color range.
;; type rcs to use it.
(defun C:rcs(/)
(setq ss (ssget '((0 . "3dsolid"))))
(setq count 0)
(repeat (sslength ss)
(setq ent (ssname ss count))
 	 (setq r (rand 10 160))
 	 (setq g (rand 10 160))
 	 (setq b (rand 10 160))
 	 (command "chprop" ent "" "color" "truecolor"
    	 	(strcat (itoa r) "," (itoa g) "," (itoa b) )
 (setq count (1+ count))
  );end repeat
);end function
;;;; Copyright (c) Jun. 1996 by Takehiko Nagakura.          ;;;;
;;;; All rights reserved.                                   ;;;;
;;;; Do not copy, use, modify or distribute this software   ;;;;
;;;; without written permission by Nagakura. Nagakura will  ;;;;
;;;; not be responsible for any consequence of its use.     ;;;;
;;;; Takehiko Nagakura  (e-mail: takehiko@mit.edu)          ;;;;
;;;;    Massachusetts Institute of Technology               ;;;;
;;;;    77 Massachusetts Ave. 10-472M, Cambridge, MA 02139  ;;;;
;;;; Last updated Feb 28, 2005 by TN for true color sample
;;;; Last updated Dec 29, 1996 by TN
;; The following pseudo-random number generator was
;; adopted from Kernighan and Ritchie's "C Programming Language"
;; second edition, p46.
;; If you want to use a random number in your program, you can just
;; copy this whole program into your program and use the function,
;; (rand min max)
;; as described below. It works, but do not ask me why this code
;; can generate fairly good randomness. If you are curious
;; to know it, some discussion on peudo-random number generator
;; is found in Paul Kohut's web page,
;; http://xarch.tu-graz.ac.at/~rurban/news/comp.cad.autocad/rand.lsp.html.
;; functions and their descriptions
;; (rand16)       : generates a random number between 1 and 32767,
;;                  that is, a positive 16 bit integer
;; (rand min max) : generates a random number between min and max.
;;                  Min and max must be an integer between 0 and 32767.
;; (c:demo)       : demo function to generate random points
(setq *SeedRand* nil) ; initialize the global
(defun rand16 ( / s )
 ; when this is used for the first time, initialize the seed
 ; from the system clock.
 (if (null *SeedRand*)
  (setq s (getvar "date"))
     (setq *SeedRand* (fix (* 86400 (- s (fix s)))))
   ) ; progn
 ) ; if
 ; To generate a psudo-sandom number sequence
 ; I use the routine described in Kernighan and Ritchie's
 ; "C Programming Language" second edition, p46
 (setq *SeedRand* (+ (* *SeedRand* 1103515245) 12345))
; trim off the bits left of the 16th bits
 (logand (/ *SeedRand* 65536) 32767)
; generates a random number between min and max.
; min and max must be a non-negative integer smaller than 32678.
(defun rand (min max / r16 range quotient remainder result)
 (setq r16         (rand16))          ; random number smaller than 32678
 (setq range       (+ 1 (- max min))) ; number of integers to be produced
 (setq quotient    (/ r16 range))     ; result in non-neg. integer
 (setq remainder   (- r16 (* quotient range)))
 (setq result      (+ min remainder))
 result
; test it
; (rand 5 7)
(defun c:demo   ( / x y n)
 (command "plan" "")
 (command "cmdecho" 0)
 (command "zoom" "window"
           (list -10000 -10000) (list 40000 40000))
 (command "pdmode" 65)
 (command "pdsize" -2)
 (repeat 500
  (setq x (rand16) ) (setq y (rand16))
  (command "point" (list x y ))
  ;AutoCAD takes color numbers between 1 and 255
  (setq n (rand 1 255))
  (command "chprop" (entlast) "" "color" n "")
  ;(print (list x y n))
(defun c:demo2   ( / x y n)
 (command "plan" "")
 (repeat 500
 ;AutoCAD true color uses numbers between 1 and 255 for rgb channels
 ;I use 100-160 range to make pastel colors.
  (setq r (rand 160 255))
  (setq g (rand 160 255))
  (setq b (rand 160 255))
  (command "chprop" (entlast) "" "color" "truecolor"
