Hello and good evening. I received a file today of architectural plans and it seems that every time i open some of the files(all files except for the title block) i am stuck to 99% in cad reading the file and i get this msg (pls see attached file).What could possibly be wrong?
I can't upload file in here because it exceeds the maximum file size.
Do these files eventually open? If not, does AutoCAD crash?
I'm still stuck at 99% right about now (and still waiting)
I wonder if using the Partialopen command would give you access to the scalelistedit command.
Okay ill try that, can a simple title block have a 20422 drawing scales in it?
Edited by iskalipsi
additional info
It would seem highly unlikely. There are Xrefs attached right?
Nope.No Xrefs Were attached Remark.
