rhines57 Posted July 20, 2010 Posted July 20, 2010 Hello all, I'm drawing a bmx frame from scratch using Inventor but I'm having trouble finding the right specs for it. What would work better is if there was a model already made that i could use. I'm drawing an electric trike compose of 3 bmx frames framed together. Thanks! Quote
JD Mather Posted July 20, 2010 Posted July 20, 2010 A good start would be to go through the built in Frame Generator tutorials. Then attach your files here when you get stuck. You might start by attaching your master skeleton file. Quote
rhines57 Posted July 20, 2010 Author Posted July 20, 2010 Heres my skeleton, its not very accurate. Its based off of frame geometry from fitting. Framesketch.zipFetching info... Quote
JD Mather Posted July 20, 2010 Posted July 20, 2010 rhines57 said: ..... its not very accurate. . I would have used all 2D sketches rather than a 3d sketch. And it would be a good idea to dimension your sketches. http://home.pct.edu/~jmather/AU2006/MA13-3%20Mather.pdf http://home.pct.edu/~jmather/AU2007/MA105-1L%20Mather.pdf Quote
