Lee Mac Posted July 19, 2010 Posted July 19, 2010 I shall apologise in advance if I am being excessively picky - and ignore me if the solution is time consuming. I find that the code box is occasionally very narrow, example here (second code part, I'm using FF) Perhaps its just me. Also, is it possible to not show the scroll bar when they are not needed or is this a VBulletin thing? As I say, I'm picky Lee Quote
The Buzzard Posted July 19, 2010 Posted July 19, 2010 Lee, I noticed the same thing this morning and I was not to fond of it myself. Quote
CADTutor Posted July 20, 2010 Posted July 20, 2010 I shall apologise in advance if I am being excessively picky No, I like picky I find that the code box is occasionally very narrow, example here (second code part, I'm using FF) By "narrow", I assume you mean "short" and if so I agree. Looking for a solution to that now. Quote
CADTutor Posted July 20, 2010 Posted July 20, 2010 OK, that is a bug in vB which I have just reported. The box should be showing a maximum of 30 lines but is stuck at just 9. Quote
Lee Mac Posted July 20, 2010 Author Posted July 20, 2010 By "narrow", I assume you mean "short" Yup Thanks David - appreciated. Quote
Kerry Brown Posted July 22, 2010 Posted July 22, 2010 OK, that is a bug in vB which I have just reported. The box should be showing a maximum of 30 lines but is stuck at just 9. Thanks David, I just came in to ask if it could be changed from it's current setting I even have this on my clipboard :- just to demonstrate I was also wondering if the setting was in a .css file that I could change locally. 30 lines would be nice. The new board is a great improvement .. thanks for the update. Quote
CADTutor Posted July 22, 2010 Posted July 22, 2010 I was also wondering if the setting was in a .css file that I could change locally. I'm afraid not, the CSS height value is generated on the fly based on the vB configuration settings and then written as an in-line style when the page is generated so using your own CSS override won't work. I'm afraid it's a temporary annoyance but it will be resolved. Quote
CADTutor Posted July 25, 2010 Posted July 25, 2010 I've implemented a temporary fix for this issue and I think the height I've set is about right. Once a proper fix is implemented by vB, I'll revert to that but for now, this should work fine. Quote
David Bethel Posted July 25, 2010 Posted July 25, 2010 Much better. It looks like the side to side slider is there to stay no mater how wide the code is. Thanks! -David Quote
