Hi,
I have a script that will plot layers automatically without me going into layer manager and changing them and then clicking plot.
The drawings i will be working with are electrical, they have many layers in one drawing. the layers are not sequentially numbered so makes the script harder to produce.
In theory i wanted a vB program were i have check boxes of the layeers and then the layers checked are pasted into the script.
Has anyone got any ideas?
the script is as follows:
  Quote
;BEGIN SCRIPT
;Command: -plot
-PLOT
;Detailed plot configuration? [Yes/No] :
;Enter a layout name or [?] :
;Enter a page setup name :
;Enter an output device name or [?] :
;Write the plot to a file [Yes/No] :
;Save changes to page setup [Yes/No]?
;Proceed with plot [Yes/No] :
;Command: useri1
USERI1
;Enter new value for USERI1 : 002
002
;Command: -layer
-LAYER
;[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]:
T
;Enter name list of layer(s) to thaw: *
S
;Enter layer name to make current or
002
F
;Enter name list of layer(s) to freeze or
T
;Enter name list of layer(s) to thaw: 0
0
;Command: -plot
-PLOT
;Command: useri1
USERI1
;Enter new value for USERI1 : 003
003
;Command: -layer
-LAYER
T
S
003
F
T
0
;Command: -plot
-PLOT
;Command: useri1
USERI1
;Enter new value for USERI1 : 005
005
;Command: -layer
-LAYER
T
S
005
F
T
0
;Command: -plot
-PLOT
;Command: useri1
USERI1
;Enter new value for USERI1 : 006
006
;Command: -layer
-LAYER
T
S
006
F
T
0
;Command: -plot
-PLOT
;Command: useri1
USERI1
;Enter new value for USERI1 : 010
010
;Command: -layer
-LAYER
T
S
010
F
T
0
;Command: -plot
-PLOT
;Command: useri1
USERI1
;Enter new value for USERI1 : 012
012
;Command: -layer
-LAYER
T
S
012
F
T
0
;Command: -plot
-PLOT
;Command: useri1
USERI1
;Enter new value for USERI1 : 013
013
;Command: -layer
-LAYER
T
S
013
F
T
0
;Command: -plot
-PLOT
;Command: useri1
USERI1
;Enter new value for USERI1 : 014
014
;Command: -layer
-LAYER
T
S
014
F
T
0
;Command: -plot
-PLOT
;Command: useri1
USERI1
;Enter new value for USERI1 : 015
015
;Command: -layer
-LAYER
T
S
015
F
T
0
;Command: -plot
-PLOT
;Command: useri1
USERI1
;Enter new value for USERI1 : 016
016
;Command: -layer
-LAYER
T
S
016
F
T
0
;Command: -plot
-PLOT
;Command: useri1
USERI1
;Enter new value for USERI1 : 017
017
;Command: -layer
-LAYER
T
S
017
F
T
0
;Command: -plot
-PLOT
;Command: useri1
USERI1
;Enter new value for USERI1 : 018
018
;Command: -layer
-LAYER
T
S
018
F
T
0
;Command: -plot
-PLOT
;Command: useri1
USERI1
;Enter new value for USERI1 : 019
019
;Command: -layer
-LAYER
T
S
019
F
T
0
;Command: -plot
-PLOT
;Command: useri1
USERI1
;Enter new value for USERI1 : 021
021
;Command: -layer
-LAYER
T
S
021
F
T
0
;Command: -plot
-PLOT
;END SCRIPT
I would write a vba or lisp a simple 1 would be just step through the layer table and answer y or n then it would write a script answer to turn off the unwanted.
You could populate a list with layer names and have a remove/add button as you pick in a dcl or form then press ok to finish.
You can also create layer groups and save, say all currently "on" within the normal layer manager.
Also current layer 1 line (setvar "clayer" 019) this is ok in scripts even though its lisp
