bugoy202 Posted July 18, 2010 Posted July 18, 2010 Could anyone help me! i'm looking for a script file or lisp that can open, bind xrefs, purge, audit, save and close a multiple drawings i one shot. Maybe i'm being lazy, but i need to do this to a 100ish drawings. Thanks, Quote
monk Posted July 21, 2010 Posted July 21, 2010 Etransmit, under the "file" menu. You can change several options, either compile all linked files (fonts, ctb, materials etc) into a zip. The way i do it is set it to just put the drawings in a folder. Set it to bind attached xrefs, purge. Very easy to use. Obviously supports multiple files. Just open up one drawing from you set and click add files. Quote
bugoy202 Posted July 21, 2010 Author Posted July 21, 2010 Thanks Monk, i really appreciate your reply on this. I'll try this one. This will really help me a lot. I'll try to ask you later if i'll encounter some problems or some questions regarding this TNX Quote
monk Posted July 21, 2010 Posted July 21, 2010 No problem, Once your in the etransmit menu, go to settings and setup one of your own. Then you can use these settings in the future Various options in there! Quote
