Jimmy Sean Posted July 16, 2010 Author Posted July 16, 2010 Try replacing the (while T with (while (eq 5 (car (grread T 15 0)))this way, it will allow you to pan around and once you hit any key or click the mouse, it will exit. Just keep in mind that it will only cycle the on/off state, etc. if your mouse is moving, but since you'll be panning around, it will work fine. When I tried your original code I could never get it to flash at all, that is why I separated the on/off. If I could get it to work your way then I'm all for that. Quote
alanjt Posted July 16, 2010 Posted July 16, 2010 This should scroll fine. I added a print to the commandline so you could see the variable change from 0 to 1 (on to off). (while (eq 5 (car (grread t 15 0))) (print (itoa (setvar 'lwdisplay (abs (1- (getvar 'lwdisplay)))))) (command "_.delay" 200) ) Quote
Jimmy Sean Posted July 19, 2010 Author Posted July 19, 2010 This should scroll fine. I added a print to the commandline so you could see the variable change from 0 to 1 (on to off). (while (eq 5 (car (grread t 15 0))) Could you explain this line to me please? Is there away to control how many on/offs before it pauses? Thanks Quote
Jimmy Sean Posted July 21, 2010 Author Posted July 21, 2010 Could you explain this line to me please? Is there away to control how many on/offs before it pauses? Thanks I figured out what the line of code means. Thanks for all the help but at this point the guy I work for doesn't like the functionality of it so I'm at a stand still with this. He doesn't like the fact that it stops unless you move the mouse. It would flash before without any input from the user and that is what he wants. Again thanks for your help. Sean Quote
alanjt Posted July 21, 2010 Posted July 21, 2010 I figured out what the line of code means. Thanks for all the help but at this point the guy I work for doesn't like the functionality of it so I'm at a stand still with this. He doesn't like the fact that it stops unless you move the mouse. It would flash before without any input from the user and that is what he wants. Again thanks for your help. Sean Sorry I never got back to you on this. I completely forgot about this thread. Quote
Jimmy Sean Posted July 21, 2010 Author Posted July 21, 2010 Not a problem, I appreciate all the help you have given. The problem with the other version is it takes too many escapes to get out of the loop and the version you helped with is it won't flash continually. I can't win. Quote
alanjt Posted July 21, 2010 Posted July 21, 2010 Not a problem, I appreciate all the help you have given. The problem with the other version is it takes too many escapes to get out of the loop and the version you helped with is it won't flash continually. I can't win. As I tell the guys around here, it's programming in AutoCAD, not magic. Quote
The Buzzard Posted July 21, 2010 Posted July 21, 2010 As I tell the guys around here, it's programming in AutoCAD, not magic. I dont know about that Alan, This picture I found of you suggests the latter. Quote
alanjt Posted July 21, 2010 Posted July 21, 2010 I dont know about that Alan, This picture I found of you suggests the latter.HaHaMan, I wish my beard was that awesome. Quote
