I'm looking to place field information into a table using Acad 2005. Lee Mac, made a great program to
  • Select your table.
  • Select your rooms in turn.
  • Click inside the cell you want the field in
the program is called scell Lisp, this program works great for selecting each Polyline object and returns the Area into the selected cell with in the table however, I have fields that are named objects/blocks and I would like to be able to select these fields and be able to place the names of these objects/blocks into the table in a similar fashion by clicking on each block rather that going through the insert field method in each cell, just would be a time saver for placing field data into a table cell in doing takeoffs. Any help would be greatly appreciated. :unsure:
