chulse Posted September 5, 2008 Share Posted September 5, 2008 Has anyone else had this problem? I set my sheets to a PDF page setup (I use Adobe Acrobat Pro7) and in 2008 I get a nice multi-page pdf file. But, in 2009, I get the first sheet and the whole thing stops ...or is it just me...? Thanks Quote Link to comment Share on other sites More sharing options...
sab423 Posted September 5, 2008 Share Posted September 5, 2008 I just tried it to see and had similar results. Mine printed the first page to pdf file I designated, but then when it went to the next page it asked for pdf file name again. So the three sheets I printed all went to separate pdf files instead of one multipage file. Quote Link to comment Share on other sites More sharing options...
chulse Posted September 5, 2008 Author Share Posted September 5, 2008 Hmm. Mine just hangs after the first sheet. What is your PUBLISHCOLLATE var set to? Quote Link to comment Share on other sites More sharing options...
sab423 Posted September 11, 2008 Share Posted September 11, 2008 The PUBLISHCOLLATE var is set to Quote Link to comment Share on other sites More sharing options...
chulse Posted September 11, 2008 Author Share Posted September 11, 2008 Well, the Autodesk sollution was to use their PDF driver and it seems to work. Must be time to upgrade my old Adobe 7 Pro Quote Link to comment Share on other sites More sharing options...
hotrodz0321 Posted September 11, 2008 Share Posted September 11, 2008 Well, the Autodesk sollution was to use their PDF driver and it seems to work. Must be time to upgrade my old Adobe 7 Pro .....so you were able to get a multi-page pdf file after you installed the recommended driver? we are about to install 09 and it would help to have an issue solved before it happens Quote Link to comment Share on other sites More sharing options...
chulse Posted September 12, 2008 Author Share Posted September 12, 2008 .....so you were able to get a multi-page pdf file after you installed the recommended driver? we are about to install 09 and it would help to have an issue solved before it happens Use the PDF driver that is included with AutoCAD - DWG to PDF.pc3 I'm told it has some of it's own problems though, like the ability to handle tiff files... I guess you just can't have everything. I'll try to remember to post here the results if I manage to get the upgrade to Acrobat Pro 9... Quote Link to comment Share on other sites More sharing options...
