Live 1 1 Posted July 13, 2010 Posted July 13, 2010 hey, i'm having a little trouble trimming this object. Can someone could have a look and tell me where i'm going wrong...? Trim.dwgFetching info... Quote
iskalipsi Posted July 13, 2010 Posted July 13, 2010 Did you mean slice? Which part are you trying to slice? Try slicing using 3 point. Quote
Live 1 1 Posted July 13, 2010 Author Posted July 13, 2010 i want to delete the part of the slanted object that is to the right of the lower vertical line (if that makes sense) Quote
iskalipsi Posted July 13, 2010 Posted July 13, 2010 Live 1 1 said: i want to delete the part of the slanted object that is to the right of the lower vertical line (if that makes sense) yes, you can do that using the slice command. Is this what you are trying to achieve? Quote
Live 1 1 Posted July 13, 2010 Author Posted July 13, 2010 Yes that's it i tried it and it worked THANKS!! Quote
