gazzalp Posted July 13, 2010 Posted July 13, 2010 hi all, we have a script written by an ex employee which does some cleaning up of a drawing before closing it. The one thing it does which i dont want it to do, is delete every layer that doesn't have anything on it. Does anyone know how to modify this code so it does everything it currently does, but will NOT delete layers? here is the code: ^C^C-PURGE;ALL;*;N;-PURGE;ALL;*;N;-PURGE;ALL;*;N;-PURGE;ALL;*;N;-PURGE;ALL;*;N;ZOOM;EXTENTS;-INSERT;"X:/AutoCAD Support George/SETTING REINSTATE.DWG";^c^c-LAYER;SET;0;;-COLOR;BYLAYER;-LWEIGHT;BYLAYER;LWDISPLAY;OFF;-LINETYPE;SET;BYLAYER;;-STYLE;AWT;ROMANS.SHX;0;0.650;0;N;N;N;-DIMSTYLE;RESTORE;AWT;^C^C-PURGE;ALL;*;N;-PURGE;ALL;*;N;-PURGE;ALL;*;N;-PURGE;ALL;*;N;-PURGE;ALL;*;N;DIMSCALE;100;QSAVE;CLOSE; Thanks Quote
CADTutor Posted July 13, 2010 Posted July 13, 2010 This is more complicated than it seems. The current script recursively purges ALL redundant entities (including layers). If you want to purge everything EXCEPT layers, the script would need to purge all other entity types independently (and there are quite a few) as you can see: Enter type of unused objects to purge [blocks/Dimstyles/LAyers/LTypes/MAterials/MUltileaderstyles/Plotstyles/SHapes/te xtSTyles/Mlinestyles/Tablestyles/Visualstyles/Regapps/Zero-length geometry/Empty text objects/All]: The resulting script would be very long and might not even succeed in purging everything (depending on entity dependencies). It would probably be easier to have a LISP routine record the current layer set, purge everything and then restore the layers. Quote
gazzalp Posted July 13, 2010 Author Posted July 13, 2010 Hmmm that makes sense, i guess if thats what i need to do then i will do it. We also have a template drawing with all our standard layers. Would it be easier to keep the code as it is (deleting any unused layers) and then at the end adding our template layers (if they are not already there?) this would save having to record the current layer set, and means we would always end up with our standard layers plus any others that we have something drawn on. thanks for your help Quote
CarlB Posted July 21, 2010 Posted July 21, 2010 Igot his idea after reading the thread "macro (not lisp) for VP visibility.." A script was used for the extra task. You could end your macro with: ;-script;makleyayers; And makelayers.scr could be something like; -layer m layer1,layer2,layer3,layer4,layer5,layer6,layer7 ;[2 returns, as in blank lines] Quote
