When I type commands on the keyboard it appears at the cursor and not command window.
I don't like it at the cursor - how can I deactivate it ?
Autocad 2010 win vista
Thanks guys - just found the answer-
Its called dynamic input - there is an icon in the same bar (bottom left) where you find the ortho mode/ object snap etc. - just click to activate /deactivate.
I must have started off mine by accidentally clicking on it. -
Dynamic input is the default so it needs to be turned off if you don't want it - or change that setting in your template file.
