Trickinitup Posted September 5, 2008 Share Posted September 5, 2008 Hi, When I plot my drawing to Adobe PDF the orientation of the drawing rotates 90 degrees relative to the paper orientation. Even though it all looks fine in print preview. Does someone know how to fix this? I am using Autocad 2007 and Adobe proffesional 7.0 Thanks Quote Link to comment Share on other sites More sharing options...
nocturne00 Posted September 5, 2008 Share Posted September 5, 2008 Check the orientation of the paper not only on the print set up, but also your settings in the PDF WRITER. if its landscape in the print setup, your PDF WRITER must also have a paper orientation of Landscape Quote Link to comment Share on other sites More sharing options...
Dipali Posted September 5, 2008 Share Posted September 5, 2008 Check the printing preferences in the property of your adobe pdf. Quote Link to comment Share on other sites More sharing options...
nocturne00 Posted September 5, 2008 Share Posted September 5, 2008 Buzzer Beater ^_^ 2:26 PM Quote Link to comment Share on other sites More sharing options...
Dipali Posted September 5, 2008 Share Posted September 5, 2008 its 11.56 am Quote Link to comment Share on other sites More sharing options...
nocturne00 Posted September 5, 2008 Share Posted September 5, 2008 Im talkin about the time in the posts Quote Link to comment Share on other sites More sharing options...
Dipali Posted September 5, 2008 Share Posted September 5, 2008 talking about same thing but it shows indian time at my end because there is a setting in the site here which shows memebers local time. Quote Link to comment Share on other sites More sharing options...
nocturne00 Posted September 5, 2008 Share Posted September 5, 2008 :lol: whao relax men,,, ur too seriuos:glare: :P ...peace Quote Link to comment Share on other sites More sharing options...
sab423 Posted September 5, 2008 Share Posted September 5, 2008 What printer driver are you using? If you have a print driver from Adobe and if that is the one your using you need to go into the custom properties to make sure its printing to the correct orientation. If you are using the driver supplied by AutoCAD DWG to PDF.pc3 you need to select the correct ANSI paper size and orientation. The sheet orientation in the printer/plotter section should match the orientation you want. Hope this helps. Quote Link to comment Share on other sites More sharing options...
ranaumair Posted September 5, 2008 Share Posted September 5, 2008 Salam (May Allah Peace Be Upon him/her) its very easy dont get dispoint. just open autocad and follow the given procedure 1------- click on file and select PAGE SETUP MANAGER 2------- set all setting according to ur requirements and close it so every time when u will plot any file into PDF autocad will select the previous setting which u set before. take care :wink: Quote Link to comment Share on other sites More sharing options...
