I'm looking for a lisp routine that removes spaces in a string.
" D-2 TV 2 " becomes "D-2TV2"
Thanks.
(defun AT:NoSpaces (str / str)
 ;; Remove all spaces from string
 ;; str - valid string
 ;; Alan J. Thompson, 03.20.09
 (if (eq (type str) 'STR)
   (while (vl-string-search " " str)
     (setq str (vl-string-subst "" " " str))
Thanks.
My 2 cents
(defun vl-remove-blanks (string)
(vl-list->string
 (vl-remove
   32
 (vl-string->list string )))
~'J'~
A variation:
(defun LM:RemoveSpaces ( str )
 (if (wcmatch str "* *")
   (LM:RemoveSpaces (vl-string-subst "" " " str)) str
You know, when I wrote the above, I considered that way, but abandoned it because I figured it would be a lot slower. I wish I would have written both and benchmarked them. Converting to/from a list is A LOT faster.
That will show me to post something I wrote a year ago and not make an attempt at writing something better.
Elapsed milliseconds / relative speed for 4096 iteration(s):
   (VL-REMOVE-BLANKS S)......1579 / 43.11 <fastest>
   (AT:NOSPACES S)..........29656 / 2.3
   (LM:REMOVESPACES S)......68078 / 1 <slowest>
Used on a string with 2000 characters.
2000 is a lot of characters - "my strings" have 20 at most. Your benchmark suggests that I choose
(vl-list->string
 (vl-remove
   32
Thanks to all of you.:)
  • 3 years later...
Hey, can someone help me briefly, how would I use that function on each item in a list , and create a new list of the new items (spaces removed)
I know it'd be mapcar....
!VALLIST
(("      " "     ") ("      " "     ") ("      " "     ") ("123" "FT") ("123"
"FT") ("123" "FT") ("123" "FT") ("123" "FT") ("272" "FT") ("661" "FT") ("123"
"FT") ("311" "FT") ("51" "FT") ("28" "FT") ("161" "FT") ("69" "FT") ("82" "FT")
("312" "TI") ("612" "FQ") ("      22" "FE") ("      12" "FT") ("312" "TI")
("612" "FQ") ("      22" "FE") ("      12" "FT") ("312" "TI") ("612" "FQ") ("
  22" "FE") ("      12" "FT") ("123" "FT") ("123" "FT") ("123" "FT") ("123"
"FT") ("123" "FT") ("272" "FT") ("661" "FT") ("123" "FT") ("311" "FT") ("51"
"FT") ("28" "FT") ("161" "FT") ("69" "FT") ("82" "FT") ("312" "TI") ("612"
"FQ") ("      22" "FE") ("      12" "FT") ("312" "TI") ("612" "FQ") ("      22"
"FE") ("      12" "FT") ("312" "TI") ("612" "FQ") ("      22" "FE") ("      12"
"FT") ("18" "TT") ("47" "FE") ("61" "FT") ("22" "TI") ("15" "TE") ("272" "FQ")
("18" "TE") ("123" "TT") ("22" "FQI") ("22" "FQ") ("18" "FE") ("92" "PI") ("12"
"PP") ("92" "TI") ("06" "PP") ("612" "FQ") ("      22" "FE") ("      12" "FT")
("312" "TI") ("612" "FQ") ("18" "TT") ("11" "TI") ("312" "TI") ("612" "FQ") ("
   22" "FE") ("      12" "FT"))
So, i'd need to pass each item in succession to the function as an argument.
(setq c 0)
(while (< c (length vallist))
(setq newitem (lm:removespaces (nth 0 vallist)))
(setq c (1+ c))
);while
Seems to work, but it gives an error...
; error: bad argument type: stringp ("      " "     ")
and you can see that the first item is just all spaces, so how would I handle this ?
And then how would I reconstruct the list, with all of the spaces removed in the items now?
I know I'm close and I'll keep tinkering, just hoping for some assistance.
Any of the three codes posted above should work
(mapcar
 '(lambda (itm)
    (mapcar 'LM:RemoveSpaces itm)
 VALLIST
Thanks Pbe. Now if only I knew to construct this logic without assistance :/
Thanks anyways though! I figured lambda and mapcar would be the best way to handle such a list
Thanks Pbe.Now if only I knew to construct this logic without assistance
Why of course you do, I think you just ran out of tracks is all. Most important is you try
...Thanks anyways though! I figured lambda and mapcar would be the best way to handle such a list
If you are meaning help with your posted code
(setq c 0)
(while (< c (length vallist));<-- suggest not to use while, i dont think you need to set a condition just process the whole list , try foreach or repeat
(setq newitem (lm:removespaces (nth 0 vallist))) ;<-- in here, you are trying to process a "list" whilst the required argument for the routine is a "string"
(setq c (1+ c))
);while
Try this way [without the use of mapcar/lambda]
(defun demo1 (lst_ / a newitem)
 (setq c (length lst_))
 (foreach lst (reverse lst_)
   (foreach itm (reverse lst)
     (setq a (cons (lm:removespaces itm) a))
   (setq newitem (cons a newitem)
  a	  nil
 newitem
or
(defun demo2 (lst_ / a c newitem)
 (repeat (setq c (length lst_))
   (foreach itm (reverse (nth (setq c (1- c)) lst_))
  a	  nil
 ) newitem
HTH
  • 4 years later...
Here's a function I'm using on a script I'm working on. Another 2 cents into the pot.
;; REMOVES INVALID ACAD CHARACTERS, EXTRA WHITESPACE, LEADING + TRAILING WHITESPACE CHARACTERS
;; by 3dwannab 21.09.18
;; Usage: (_3dwannab_RemoveSnvalidwithExtraWhiteSpaceChars "  a messed   |  up string goes, : here  ")
;; Returns: "a messed up string goes here"
(defun _3dwannab_RemoveSnvalidwithExtraWhiteSpaceChars ( str / regex )
	(setq regex (vlax-create-object "Vbscript.RegExp"))
	(vlax-put-property regex "Global" 1)
	(vlax-put-property regex "Pattern" "[<>\/\\\"\:\?\*\|\,\=`\;]")
	(setq str (vlax-invoke-method regex "Replace" str (strcat "")))
	(vlax-put-property regex "Pattern" "\\s+")
	(setq str (vlax-invoke-method regex "Replace" str (strcat " ")))
	(vlax-put-property regex "Pattern" "^\\s+|\\s+$")
	(vlax-release-object regex)
	str
To just remove all whitespace characters including leading and trailing use.
(defun _3dwannab_RemoveAllWhiteSpaceChars ( str / regex )
	(vlax-put-property regex "Pattern" "\\s*")
	str
Edited by 3dwannab
Added add. code
3dwannab,
Obtaining and releasing objects that are external to ACAD is a rather slow approach...
If you decide to stick with regex,  then I'd advise you to modify the subfunction to accept a list of strings as argument,
so you could obtain once the regex object, process all the strings and then release it.
Also you might occur on some problems with formatted mtexts, since their content may look something like this:
Quote
"{\\fArial|b0|i1|c204|p34;\\C2;s\\fArial|b1|i1|c204|p34;t\\L\\C1;ri\\fArial|b1|i0|c204|p34;\\C4;n\\fArial|b0|i0|c204|p34;g}"
another $0.02, hiccup - overrides strcase
(read (strcat "(" (vl-string-translate "|:," "   " "  a messed   |  up string goes, : here  ")")") )
Quote
 (A MESSED UP STRING GOES HERE)
p/s:  off topic regEx - how about removing  previous forum Tags mass? eg: [ color ] ,  [ B ] , etc..
4 hours ago, Grrr said:
3dwannab,
In my script I am also using Lee Macs unformat but for the propose of this thread I thought that removing invalid characters and showing a regular expression method would also be useful as I am quite familiar with it. What do you mean list of strings. The lisp I'm working on atm only parses one string and not a list. It's a Rename block with selected text routine. An edit of Alan Js Rename block routine I had from away back.
Simple:
To match [ colour ] or [ B ] you could use. But I would need more concrete examples to ensure the proper syntax.
\[\s*[^\]]{1,6}\s*\]
Edited by 3dwannab
  • 4 months later...
Hello to all!
I have a list:
(("Fax") ("HP LaserJet MFP M725 PCL 6") ("Microsoft Print to PDF") ("Microsoft XPS Document Writer") ("NEZH-HP725-02 (HP LaserJet MFP M725)"))
how do i get a list of this type:
("Fax" "HP LaserJet MFP M725 PCL 6" "Microsoft Print to PDF" "Microsoft XPS Document Writer" "NEZH-HP725-02 (HP LaserJet MFP M725)")
and then do the following (for example):
(setq a "Fax"
      aa "HP LaserJet MFP M725 PCL 6"
      aaa "Microsoft Print to PDF"
      aaaa "Microsoft XPS Document Writer"
      aaaaa "NEZH-HP725-02 (HP LaserJet MFP M725)"
I want to assign a variable to each printer in the list.
I will be grateful to everyone who will help.
_$ (apply 'append '(("Fax") ("HP LaserJet MFP M725 PCL 6") ("Microsoft Print to PDF") ("Microsoft XPS Document Writer") ("NEZH-HP725-02 (HP LaserJet MFP M725)")))
I would strongly advise against assigning each element of a list to a separate variable in favour of manipulating the list using the wealth of list functions available in AutoLISP, but if you really must:
_$ (setq l (apply 'append '(("Fax?") ("HP LaserJet MFP M725 PCL 6") ("Microsoft Print to PDF") ("Microsoft XPS Document Writer") ("NEZH-HP725-02 (HP LaserJet MFP M725)"))))
("Fax?" "HP LaserJet MFP M725 PCL 6" "Microsoft Print to PDF" "Microsoft XPS Document Writer" "NEZH-HP725-02 (HP LaserJet MFP M725)")
_$ (setq s "a")
"a"
_$ (foreach x l (set (read s) x) (setq s (strcat s "a")))
"aaaaaa"
_$ a
"Fax?"
_$ aa
_$ aaa
_$ aaaa
_$ aaaaa
Edited by Lee Mac
_$ (setq s "a")
"a"
"aaaaaa"
_$ a
"Fax?"
_$ aa
_$ aaa
_$ aaaa
_$ aaaaa
Thank you very much Lee Mac, that's what I need. And I will definitely remember your words "I would strongly advise against assigning each element of a list to a separate variable".
The choice would be better through a dcl for choosing you could use Lee's listbox dcl or a button dcl.
These posts are not really releative to the original post you would have been better starting a new one in the lisp section.
