Hi to all, i'm a newbie :)
Anyway i have a code segment which is deleting duplicate points in the selection area, it searches entire selection set and compare points in 2 dimension. for example, code runned 1 minute and 40 secs for 240.000 points. if u interested i can share the code segment
Thank you.
First post and he's already teasing us. Smarty pants.
thanks for replying me ReMark. Are you interested ?
Sure thing fallen. No bugs or viruses in it are there? Can't be too careful these days you know.
Sure ain't in it, it's just a code segment written in lisp, and still needs modification u know, and still ended with an error :) but it works!
Why are we even discussing this? :huh:
If you want to post the code, then post it. But I don't know why anyone would want a lisp routine that doesn't work? You say it ends in an error, so that means it doesn't work.
I have moved this thread to the lisp section, so go ahead and post your code and maybe one of the guys here will take a look at it and give you a suggestion as to how to get it working correctly.
sorry for this, but as i said i'm a newbie here, sorry for this again, next post i'll give the code
Why didn't you just put it in your last post? :roll:
I'm starting to get the feeling that you're just trying to boost your post count so you can post a link to some bogus website. :glare:
I will be expecting to see the code in your next reply.
The above is referred to as a "gotcha". You better pony up fallen or else it is off to the gallows with you.
no! ok here is the code i just trying to fix the error.
waiting for suggestions
(defun dupsil ()
(setq i 0 p1 nil p2 nil p3 nil p4 nil i1 0 i5 0)
(setq sec (ssget '((0 . "POINT"))))
(setq uzunluk (sslength sec))
(while (
(setq p4 nil ss1 nil)
(if (/= (setq b (cdr (assoc 10 (entget (ssname sec i))))) nil)
(setq p1 (mapcar '(lambda (x y) (+ x y)) b '(0 200 0)))
(setq p2 (mapcar '(lambda (x y) (+ x y)) b '(200 -200 0)))
(setq p3 (mapcar '(lambda (x y) (+ x y)) b '(-200 -200 0)))
(setq p4 (append p4 (list p1) (list p2) (list p3)))
(setq p4 (apply 'append (list (mapcar '(lambda (x) (list (car x) (cadr x))) p4))))
(setq ss1 (ssget "_CP" p4))
(if (> (sslength ss1) 1)
(setq i5 (1+ i5))
(setq i1 0 p5 nil)
(while (
(setq p5 (append p5 (list (cdr (assoc 10 (entget (ssname ss1 i1)))))))
(setq i1 (1+ i1))
(setq p5 (apply 'append (list (mapcar '(lambda (x) (list (car x) (cadr x))) p5))))
(setq p6 (vl-sort-i p5
(function
(lambda (e1 e2)
(setq i1 0)
(while (
(if (
(setq i5 (1+ i5))
(entdel (ssname ss1 (nth i1 p6)))
(ssdel (ssname ss1 (nth i1 p6)) sec)
(setq i1 (1+ i1))
(setq i (1+ i))
don't mind the error!! it is working u can test it by re-select the point set after running the code.
Would something like this not suffice?
(defun c:DelDupes ( / ss )
 ;; © Lee Mac 2010
 (if (setq ss (ssget "_X" '((0 . "POINT"))))
     (lambda ( i / e1 e2 p1 p2 )
       (while (not (minusp (setq j (1- i) i (1- i))))
         (setq e1 (ssname ss i) p1 (cdr (assoc 10 (entget e1))))
         (while (not (minusp (setq j (1- j))))
           (setq e2 (ssname ss j) p2 (cdr (assoc 10 (entget e2))))
           (if (equal p1 p2) (progn (entdel e2) (ssdel e2 ss)))
     (sslength ss)
Lee Mac, i will run the code ,
and discuss it.
Thanks
I'm sure I'm missing something, but would this work?
(defun test (/ ss lst)
 (if (setq ss (ssget "_:L" '((0 . "POINT"))))
   ((lambda (i / p)
      (while (setq e (ssname ss (setq i (1+ i))))
        (if (vl-position (setq p (cdr (assoc 10 (entget e)))) lst)
          (entdel e)
          (setq lst (cons p lst))
     -1
 ss
BTW, read this: Code Posting Etiquette
Lee Mac, i have ran the code for 34000 points (not random, acquired from terrain readings) i think it overflows or something. i stopped it. cause, 2 minutes elapsed and still there is no response. i think it searches the points one by one.
Thank you
   ((lambda (i / p)
          (entdel e)
     -1
 ss
Nice one Alan, much better - mine was stupidly running through the SelSet too many times... :geek:
alanjt, thanks for post, but i think it may suffers at large numbers of points but i will run your code.
thank u
alanjt, i' ve ran ur code it is a good one, tested ur code for 34000 points, elapsed time 65 seconds,
thank u
Thanks. I was sure I was missing something. :)
thank u
You're welcome. Here's a cleaner copy of it as an actual routine:
(defun c:DDP (/ ss lst)
 ;; Delete Duplicate Points
 ;; Alan J. Thompson, 07.06.10
   ((lambda (i / p)
          (entdel e)
     -1
thanx for the code, but have u tried mine?, it takes lesser time about 10 secs for 34000 pts, if u can fix the error of mine i'll be so pleased.
thank u
