shakey1057 Posted July 4, 2010 Posted July 4, 2010 I do a lot of cnc mill programing. I use autocad to find the path i need. but i have not found a easy way to display or print the x y z points in a chart. what i would like is some type of list that will let me print a list of x y z and rad info.Is there a way to get this info with out dimentioning and moving this info by hand? Quote
bestali Posted July 4, 2010 Posted July 4, 2010 I do a lot of cnc mill programing. I use autocad to find the path i need. but i have not found a easy way to display or print the x y z points in a chart. what i would like is some type of list that will let me print a list of x y z and rad info.Is there a way to get this info with out dimentioning and moving this info by hand? solid works may help you. Quote
opreese Posted February 2, 2011 Posted February 2, 2011 Creating a path for cnc use, would that be the function of cam software? I wonder, how shakey1057 was using autocad to find the path? Quote
