I am working on a macro that will put all my entities in a drawing color to bylayer. Here is my code so far and it works but I have to select each entity one at a time.
(defun C:CBL ( / oldData newData)
(While
 (setq oldData (entget(car(nentsel))))
 (setq newData (subst (cons 62 256)(assoc 62 oldData)oldData))
 (entmod newData)
 (command "REGEN")
);end while
Question #1
How would I use ssget to accomplish this task? (ssget "x")
I am having trouble understanding how to use ssget.
Question #2
(subst (cons 62 256)(assoc 62 oldData)oldData) from my above code.
I don't 100% understand how this works. Why do I use oldData at the end of this function? Why do I have to call oldData twice? Can someone explain what each oldData is doing?
Question #3
My ultimate goal is to be able to put all entities in a drawing plotstyle to bylayer. This seems to be a much bigger task from what I am reading.
Is there not a DXF code for plot syle? How do I access the plotsyles to modify it. Seems it is a vl functions but I am not at that level of understanding LISP yet, so how was it accomplished before Visual Lisp done in "vanilla LISP"?
Thanks
You can select all the objects in your drawing and stright to the pop-up-list of Layer Colors and select it ByLayer and that will solve the issue.
Regards
Tharwat
this might be a shortcut
(command "change" "all" "" "properties" "color" "bylayer" "")
draw backs are:
if you are in model space it will only change those objects
if you are in paper space it will only chanf that tab
if you want to change all objexts in model and paper you need to use ssget "x" then use a while loop with ssname
This will select all entities in your drawing
(setq objs (ssget "_x"))
Regards.
Tharwat
2008 had the SetByLayer command.
Thanks Alan
This command does everything I want my macro to do. I wish I knew about this command before now, This is great. Thanks :D
But
I am still on the quest to understand how to do it via lisp...
Can you take a crack at question #2 for me? I would like to understand how the "assoc" function works and why I have to call out oldData twice.
Thanks
Answer to question #2:
Subst has three parameters that must be filled.
(subst <new> <old> <list>)
= the item you want to replace the old with.
= the old item you want to replace with new (you don't know it, so you must call it from the list)
= the list you want to edit.
eg.
Command: (setq lst (list (cons 1 "ALAN") (cons 2 "THOMPSON")))
((1 . "ALAN") (2 . "THOMPSON"))
Command: (assoc 1 lst)
(1 . "ALAN")
Command: (subst (cons 2 "NAME") (assoc 2 lst) lst)
((1 . "ALAN") (2 . "NAME"))
If I want to replace item A with B, I have to call it from the list first.
You're only calling the list once. The second parameter of subst is you extracting the item to replace from the list.
eg.
(1 . "ALAN")
Thanks again Alan
It sounds so straight forward the way you put it, I could not find a good example to explain it to me in a way that I could get my head around it.
Not to be greedy here but...
From my understanding so far... If I want to get information about an element I have to use (entsel) & (entget) together. Where (entsel) allows me to select the element and (entget) pull the information from the element. (DxF codes)
But (ssget) seems to work differently.
(ssget) seems to work as a selection/filter tool. Where I have to provide (ssget) a dot list to work from. So if I used (ssget "x") this would put all my drawing elements into a selection set. But it seems I have to specify what I want to work with from the selection set, example: (0 . "Line") or (8 . 256)
I can't use this selection set on multiple object such as "line" & "circles", I have to choose one or the other.
Am I on the right track or is there more to ssget?
Thanks again
Use of subst outside of editing an entity list:
eg.
Command: (setq lst (list "I'M" "SINGLE"))
("I'M" "SINGLE")
Command: (subst "MARRIED" "SINGLE" lst)
("I'M" "MARRIED")
This will also come in handy: AutoLISP Reference
You can use as much stuff together for ssget.
eg.
(ssget "_X" '((0 . "LINE,ARC,*POLYLINE") (8 . "PIZZA")))
This will select all lines, arcs and *polylines (works on same filtering principals as wcmatch) that reside on layer PIZZA.
eg.
("I'M" "SINGLE")
("I'M" "MARRIED")
Thanks for the Reference Manual this will be very handy:thumbsup:
You're welcome. You can also type out a function in VLIDE, highlight and click on the help button and it will give you a full explanation of it. :wink:
eg.
BAM, thank you
Last question, I promise (at least in this thread and for today)
What is the * for before polyline? Why does the poly get the * and none of the other elements?
BAM, thank you
To select LWPolylines and Polylines. As I mentioned, look at wcmatch.:wink:
eg.
Ok, I'm sorry, one more question since I am here and thinking about it.
(wcmatch, wild card match, I am reading about it now, thanks for the point)
My question:
(ssget "_x" '((0 . "line,arc,*polyline")
The "_x" will select all elements in my drawing and the (0 . "line,arc") will filter out the lines and arcs from this selection set.
So ssget is nothing more than a selection set filter? (end of story?)
entsel/nentsel/nentselp are single entity object selection.
ssget is a multiple entity selection with very extensive filter options.
Alan
Thank you for helping me understand the ssget function, the user guide and for introducing me to wcmatch.
My main confusion came from me trying to use (ssget) the same way as (entget) but for multiple objects... I am new to all this lisp stuff, so getting my head around it and swimming in too much information confusses me.
Our discussion and the following web site helped me understand, maybe it will help another lost mind too.
http://rkmcswain.blogspot.com/2008/08/exploring-autolisp-ssget-function-part.html
http://rkmcswain.blogspot.com/2008/08/exploring-autolisp-ssget-function-part_20.html
Thanks again
