mitchellrodhous Posted June 28, 2010 Posted June 28, 2010 Hi All, Well wenn I look to the greatests LISP Routine's from some people over here I always see a kind of Pop up/dialog box were you create you're function. like the attachments image... My question; is theire an small basic tutural, or could someone tell me how I can create thoose pop ups/dialog box? I think it is also posseble to activate diverent LISP routines in one LISP/pop up/dialog box. [img=http://www.cadtutor.net/forum/attachment.php?attachmentid=10883&d=1237303513] Above you see an pop up/dialog box were you can create something by values insertion in this pop up/dialog box. Anyone knows good tutoral? Regards MR Quote
MSasu Posted June 28, 2010 Posted June 28, 2010 You can start with those tutorials to learn about DCL interfaces. Regards, Quote
manirpg Posted June 28, 2010 Posted June 28, 2010 Hi, Here some good sites, so u can get DCL tutorials for ur reference..... http://jefferypsanders.com/ http://www.afralisp.net/ Direct link http://www.jefferypsanders.com/autolisp_DCL.html http://www.afralisp.net/dialog-control-language/ Regards mani:D Quote
mitchellrodhous Posted June 28, 2010 Author Posted June 28, 2010 well, I had some sparetime, so I had time to read thoose tutorals, I used one of thoose turtorals for my basic form (see attachments). Changed it to my specifics. Aftyer all, ended not knowing how to go on... Maybe someone, also has sparetime, can check up, also play the LISP, see what I am trying to reach and help me on. I am trying to select the type cabinet on the leftside (I wrote this cabinets in LISP placed somewere else) On the rightside I want to add the size, three boxes with one length, second widht, third has to be depth. By clicking on the button "OK" he has to use a LISP routine belong to the type cabinet on the left. uses the sizes I added on the rightside. ps1: It can be that some information given by the dcl or lsp file isn't even necessary for my options, I already noticed just copied from internet and changed it. Hope for any response trying to finish it. Regards MR samp6.DCL samp6.LSP Quote
mitchellrodhous Posted June 29, 2010 Author Posted June 29, 2010 weel I made a bit improvement myself... maybe somebody can explane me something.... I marked in my dcl code something in red and green.. samp6 : dialog { //dialog name label = "Cabinet Drawer V2.1" ; //give it a label : row { //define row :boxed_radio_column { //define radio column label = "Type" ; //give it a label : radio_button { //define radion button key = "[color=darkgreen]rb1[/color]" ; //give it a name label = "Cabinet free standing" ; //give it a label value = "1" ; //switch it on } //end definition : radio_button { //define radio button key = "[color=darkgreen]rb2[/color]" ; //give it a name label = "Cabinet with back" ; //give it a label } //end definition } //end radio column } //end row : boxed_column { //define boxed column label = "&Size"; //give it a label : edit_box { //define edit box key = "[color=red]eb1[/color]" ; //give it a name label = "Length :" ; //give it a label edit_width = 10 ; //30 characters } //end edit box //end edit box : edit_box { //define edit box key = "[color=red]eb2[/color]" ; //give it a name label = "Widht :" ; //give it a label edit_width = 10 ; //30 characters } //end edit box //end edit box : edit_box { //define edit box key = "[color=red]eb3[/color]" ; //give it a name label = "Depth :" ; //give it a label edit_width = 10 ; //30 characters } //end edit box //end edit box : edit_box { //define edit box key = "[color=red]eb4[/color]" ; //give it a name label = "Materialethickness :" ; //give it a label edit_width = 10 ; //30 characters } //end edit box //end edit box } //end boxed column : boxed_column { //define boxed column label = "&Specifics"; //give it a label : edit_box { //define edit box key = "[color=red]eb5[/color]" ; //give it a name label = "Back offset :" ; //give it a label edit_width = 10 ; //30 characters } //end edit box //end edit box : edit_box { //define edit box key = "[color=red]eb6[/color]" ; //give it a name label = "Thickness back :" ; //give it a label edit_width = 10 ; //30 characters } //end edit box //end edit box } //end boxed column ok_cancel ; //predifined OK/Cancel : row { //define row : image { //define image tile key = "im" ; //give it a name height = 1.0 ; //and a height width = 1.0 ; //and now a width } //end image : paragraph { //define paragraph : text_part { //define text label = "Designed and Created"; //give it some text } //end text : text_part { //define more text label = "By MR. CAD - MITCHELL RODHOUSE"; //some more text } //end text } //end paragraph } //end row } //end dialog I want to use the red marked falues as falues for the lisp I marked in green. (I have write lisp files were it ask in the commandline for the falues I'll want to put into this dialog). so an other thing, I want to activate one of two lisp files by clicking on that radio-button. Any help would be appriciated! Best Regards MR Quote
mitchellrodhous Posted June 29, 2010 Author Posted June 29, 2010 well not that much response, I hoped theire were experts enough in this forums to help me out... Does anyone know how I can use the information I insert in to this dialog box? I think I just have to insert some command prompts, but I am not knowing were to start.... LISP file (defun C:samp6 () ;define function (setq dcl_id (load_dialog "samp7.dcl")) ;load dialog (if (not (new_dialog "samp6" dcl_id) ;test for dialog );not (exit) ;exit if no dialog );if (setq w (dimx_tile "im") ;get image tile width h1 (dimy_tile "im") ;get image tile height b "eb2" ;Set Widht of the cabinet h "eb1" ;Set Hight of the cabinet d "eb3" ;Set Depth of the cabinet m "eb4" ;Set materialthickness ba "eb5" ;Set offset back bat "eb6" ;Set thickness back );setq (start_image "im") ;start the image (fill_image 0 0 w h1 5) ;fill it with blue (end_image) ;end image (action_tile "rb1" "(setq hole \"site\")") ;store hole type (action_tile "rb2" "(setq hole \"shop\")") ;store hole type (action_tile "rb3" "(setq hole \"hid\")") ;store hole type (action_tile "rb4" "(setq hole \"ctsk\")") ;store hole type (action_tile "rb5" "(setq hole \"elev\")") ;store hole type (action_tile "rb6" "(setq hole \"slot\") ;store hole type (mode_tile \"eb1\" 0) ;enable edit box (mode_tile \"eb1\" 2)") ;switch focus to edit box (action_tile "cancel" ;if cancel button pressed "(done_dialog) (setq userclick nil)" ;close dialog, set flag );action_tile (action_tile "accept" ;if O.K. pressed (strcat ;string 'em together "(setq notes (get_tile \"eb1\"))" ;get notes " (done_dialog)(setq userclick T))" ;close dialog, set flag );strcat );action tile (start_dialog) ;start dialog (unload_dialog dcl_id) ;unload (if userclick ;check O.K. was selected (progn );progn );if userclick (princ) );defun C:samp (princ) DCL file samp6 : dialog { //dialog name label = "Cabinet Drawer V2.1" ; //give it a label : row { //define row :boxed_radio_column { //define radio column label = "Type" ; //give it a label : radio_button { //define radion button key = "rb1" ; //give it a name label = "Cabinet free standing" ; //give it a label value = "1" ; //switch it on } //end definition : radio_button { //define radio button key = "rb2" ; //give it a name label = "Cabinet with back" ; //give it a label } //end definition } //end radio column } //end row : boxed_column { //define boxed column label = "&Size"; //give it a label : edit_box { //define edit box key = "eb1" ; //give it a name label = "Length :" ; //give it a label edit_width = 10 ; //30 characters } //end edit box //end edit box : edit_box { //define edit box key = "eb2" ; //give it a name label = "Widht :" ; //give it a label edit_width = 10 ; //30 characters } //end edit box //end edit box : edit_box { //define edit box key = "eb3" ; //give it a name label = "Depth :" ; //give it a label edit_width = 10 ; //30 characters } //end edit box //end edit box : edit_box { //define edit box key = "eb4" ; //give it a name label = "Materialethickness :" ; //give it a label edit_width = 10 ; //30 characters } //end edit box //end edit box } //end boxed column : boxed_column { //define boxed column label = "&Specifics"; //give it a label : edit_box { //define edit box key = "eb5" ; //give it a name label = "Back offset :" ; //give it a label edit_width = 10 ; //30 characters } //end edit box //end edit box : edit_box { //define edit box key = "eb6" ; //give it a name label = "Thickness back :" ; //give it a label edit_width = 10 ; //30 characters } //end edit box //end edit box } //end boxed column ok_cancel ; //predifined OK/Cancel : row { //define row : image { //define image tile key = "im" ; //give it a name height = 1.0 ; //and a height width = 1.0 ; //and now a width } //end image : paragraph { //define paragraph : text_part { //define text label = "Designed and Created"; //give it some text } //end text : text_part { //define more text label = "By MR. CAD - MITCHELL RODHOUSE"; //some more text } //end text } //end paragraph } //end row } //end dialog regards MR Quote
MSasu Posted June 29, 2010 Posted June 29, 2010 My suggestion is to follow the above tutorials and after start to combine the simple dialogs that you designed during those lessons into more complex ones. Next step will be to download some examples from this forum and try to understand their code. Good luck! Regards, Quote
