Lee Mac Posted June 23, 2010 Posted June 23, 2010 I end up posting these all over the forum, so I might as well post a lot of them in one place for those who are interested. _________________________________________________________ Explanation of the Apostrophe: http://www.cadtutor.net/forum/showpost.php?p=258390&postcount=20 Explanation of Logand/Logior: http://www.cadtutor.net/forum/showpost.php?p=298061&postcount=8 Working with Attributes: http://www.cadtutor.net/forum/showpost.php?p=330778&postcount=2 Explanation of Conditionals (CAB/Lee Mac) http://www.cadtutor.net/forum/showpost.php?p=173196&postcount=10 http://www.cadtutor.net/forum/showpost.php?p=240943&postcount=2 http://www.cadtutor.net/forum/showpost.php?p=273108&postcount=12 Selection Set to List http://www.cadtutor.net/forum/showpost.php?p=248285&postcount=2 Block rename: http://www.cadtutor.net/forum/showpost.php?p=242147&postcount=24 VL Method Differences: http://www.cadtutor.net/forum/showpost.php?p=258403&postcount=9 Starting LISP: http://www.afralisp.net/ http://www.jefferypsanders.com/autolisptut.html http://ronleigh.info/autolisp/index.htm More Advanced LISP Tutorials/Help: http://augiru.augi.com/content/library/au07/data/paper/CP311-4.pdf http://mitpress.mit.edu/sicp/full-text/book/book-Z-H-4.html http://www.cs.cmu.edu/afs/cs.cmu.edu/project/ai-repository/ai/html/cltl/clm/node1.html DCL Tutorials: http://www.jefferypsanders.com/autolisp_DCL.html http://www.afralisp.net/ Visual LISP Editor: http://www.afralisp.net/vl/vlisp.htm http://www.afralisp.net/vl/vl-edit.htm http://midpointcad.com/au/docs/lakose_The_Visual_LISP_Developers_Bible.pdf Error Handlers: http://www.afralisp.net/lispa/lisp6.htm http://www.cadtutor.net/forum/showthread.php?t=33966 http://www.cadtutor.net/forum/showpost.php?p=261049&postcount=3 -4 SelectionSets: http://www.afralisp.net/lisp/filter.htm http://www.theswamp.org/index.php?topic=28672.0 Layer Renaming: http://www.cadtutor.net/forum/showthread.php?t=38810 Attributes in VL: http://www.cadtutor.net/forum/showpost.php?p=259620&postcount=9 PaperSpace/ModelSpace Objects: http://www.cadtutor.net/forum/showpost.php?p=259934&postcount=13 Vla-File-Systime: http://www.cadtutor.net/forum/showthread.php?t=38331 Linking Objects with XData: http://www.cadtutor.net/forum/showpost.php?p=251211&postcount=12 Explanation of a LISP function (Text replacement): http://www.cadtutor.net/forum/showpost.php?p=264546&postcount=15 Explanation of a LISP function (Text Height Change): http://www.cadtutor.net/forum/showpost.php?p=306576&postcount=14 Explanation of a LISP function (Reinsert all blocks @ 0,0,0): http://www.cadtutor.net/forum/showpost.php?p=309366&postcount=15 SSGet Available Options: http://www.theswamp.org/index.php?topic=29972 Localising Variables: http://www.cadtutor.net/forum/showpost.php?p=265649&postcount=4 Express Tools Functions: http://www.afralisp.net/lisp/acet-utils.htm http://www.theswamp.org/index.php?action=dlattach;topic=28777.0;attach=12477 http://www.theswamp.org/index.php?topic=13719.0 http://www.theswamp.org/index.php?topic=19505.0 Entmake: http://www.theswamp.org/index.php?topic=4814.0 Undocumented LISP Functions: http://www.manusoft.com/cgi-bin/NoFrames.pl?referer=http://www.manusoft.com/resources/AcadExposed/Index.stm&header=Header.stm&toc=TOC.stm&main=Main.stm#AutoLISP Auto-Loading LISP (ACADDOC.lsp etc): http://www.theswamp.org/index.php?topic=9211.0 http://www.theswamp.org/index.php?topic=20492.0 http://www.cadtutor.net/faq/questions/53/How+do+I+automatically+load+variables%3F AutoCAD Command Prefixes: http://www.cadforum.cz/cadforum_en/qaID.asp?tip=2425 Deleting DWS Associations: http://www.cadtutor.net/forum/showthread.php?t=43380 Car/Cadr/Caddr Explained: http://ronleigh.info/autolisp/afude09.htm http://www.theswamp.org/index.php?topic=31473.0 Default Options: http://www.cadtutor.net/forum/showthread.php?t=39634 Script Writer: http://www.cadtutor.net/forum/showpost.php?p=295487&postcount=23 Demise of VBA: http://www.cadtutor.net/forum/showthread.php?t=32857 Command Vs Entmake Vs VL: http://rkmcswain.blogspot.com/2007/12/command-vs-entmake-vs-vla-add.html Explanation of Boole Function: http://www.cadtutor.net/forum/showpost.php?p=306339&postcount=9 Varying ways to Change Text Height: http://www.cadtutor.net/forum/showpost.php?p=296877&postcount=4 What are vl*,vlax* etc?: http://www.cadtutor.net/forum/showpost.php?p=318549&postcount=2 Setq Vs. Set: http://www.theswamp.org/index.php?topic=27226.msg328322#msg328322 AutoCAD Animation: http://www.cadtutor.net/forum/showthread.php?t=45146 http://www.cadtutor.net/forum/showthread.php?t=1202 http://www.cadtutor.net/forum/showthread.php?t=883 Safearrays/Variants: http://www.theswamp.org/index.php?topic=31674.0 http://www.theswamp.org/index.php?topic=29248.0 DDAtte2 (with visibility toggles): http://www.cadtutor.net/forum/showpost.php?p=308469&postcount=5 _________________________________________________________ Enjoy! Lee 2 3 Quote
ReMark Posted June 23, 2010 Posted June 23, 2010 Jeez, not very many links are there? . . . . . . . :lol: Just having some fun with you Lee. Looks like you've been very busy. I'm sure your efforts will be appreciated by many. 2 Quote
Lee Mac Posted June 23, 2010 Author Posted June 23, 2010 Thanks, its just what I've accumulated over the time I've been here - if I take time to explain something to someone in detail, I tend to save the link so I don't have to say it all over again Quote
Lee Mac Posted June 23, 2010 Author Posted June 23, 2010 I should probably add this too: http://www.theswamp.org/index.php?topic=24700.0 2 1 Quote
anna575 Posted September 11, 2010 Posted September 11, 2010 Wow, what a fantastic site. I think it’s a good opportunity for dream career. Thank u very much. :D Quote
Se7en Posted October 15, 2010 Posted October 15, 2010 Question: Why would Structure and Intrip. of Computer programs [ http://mitpress.mit.edu/sicp/full-text/book/book-Z-H-4.html ] be listed under a title of "More Advanced LISP Tutorials/Help"? ...SICP is "introduction" (101, basic, entry-level, etc.). Quote
tomhamlet Posted October 25, 2012 Posted October 25, 2012 When I asked ReMark how to go about getting more information on lisp, he refered me to this thread, when I got here i saw why. This is a great thread and I cant wait to check these sites out! Thanks Lee Mac! Quote
Baber62 Posted April 26, 2016 Posted April 26, 2016 (edited) Hi Lee, Now that I have got my Masters in Transportation over and done with and before I embark on the PhD I have got about 3/4 months in which I intend to learn and brush up on my Lisp (not the speech impediment). The routines you and others have developed have seriously enhanced the work I do in AutoCAD. Thanks Lee for all your assists and advice via these forums. Edited April 26, 2016 by Baber62 spelling Quote
Grrr Posted April 2, 2017 Posted April 2, 2017 Waaaw, very nice collection! Please keep collecting your explanations here. Quote
Cad64 Posted April 2, 2017 Posted April 2, 2017 Great list of explanations Lee. I wasn't aware of this thread. It's now a Sticky so it doesn't get lost in the mix. Quote
Lee Mac Posted April 2, 2017 Author Posted April 2, 2017 Many thanks Rod - I'm pleased to see it's still proving useful after all these years. Quote
Romero Posted May 7, 2019 Posted May 7, 2019 On 6/23/2010 at 9:16 PM, Lee Mac said: I end up posting these all over the forum, so I might as well post a lot of them in one place for those who are interested. 17/5000 Thanks for everything @Lee Mac Quote
