qball Posted June 23, 2010 Posted June 23, 2010 Acad 2010, current updates applied. I have a drawing that is about 3.3MB. I use quite a few blocks and sometimes xclipped blocks within other blocks (if that's relevant), and I use paperspace viewports on my layouts. A layout with 11 viewports takes over a minute to load the layout. More viewports, longer wait. If i go into a viewport, edit a block and save the block it takes seemingly forever to load the screen again. I turned REgenauto OFF because the program would actually crash sometimes. I believe that utilizing paperspace is quite common, but is everyone's this slow? Anything I can do to fix it? Quote
lpseifert Posted June 23, 2010 Posted June 23, 2010 If it's mainly a problem when switching layouts, try mucking with the Layout Regen Options in Options. Also be sure you don't have a bloated Scalelist. Quote
qball Posted June 23, 2010 Author Posted June 23, 2010 graphics card is NVIDIA GeForce GTS 240 (1 GB) Dell Vostro 430 Intel Core i7 2.96 GB Ram I just did MAXVP and it took over 5 minutes to regenerate. I'm checking on the other computers in the office. Quote
qball Posted June 23, 2010 Author Posted June 23, 2010 is Scalelist a system function or only pertain to each file? I don't want to delete a bunch that I need to use in a different file and have to re-create them. Quote
lpseifert Posted June 23, 2010 Posted June 23, 2010 Scalelists are drawing specific... if you have an extraordinary amount of scales (50-100+) try this Quote Command: -SCALELISTEDIT Enter option [?/Add/Delete/Reset/Exit] : R Reset scale list to defaults? [Yes/No] : Y Scale list reset to default entries. Enter option [?/Add/Delete/Reset/Exit] : E Quote
nukecad Posted June 23, 2010 Posted June 23, 2010 qball said: .................. A layout with 11 viewports takes over a minute to load the layout. More viewports, longer wait. .......... 11 viewports? Maybe I'm old fashioned but I've never had more than 4 or 5 on the same drawing. (4 or 5 different viewport scales). I have seen drawings where the drafter has drawn things all over modelspace and then used lots of viewports to get them together in paperspace but this seems a long way round to me. Quote
ReMark Posted June 23, 2010 Posted June 23, 2010 The most I ever had was 16 viewports in a single drawing. Normally it's around 8. Quote
qball Posted June 23, 2010 Author Posted June 23, 2010 I think I am finished with multiple viewports.... too troublesome. With the complicated jobs I need to draw large sections and do blow-up details of it in multiple areas. The alternative is make the large sections into blocks and then xclip all the smaller parts onto a single sheet with a single viewport. Oh well, I thought I was doing the right thing. Apparently Autocad disagrees. Quote
ReMark Posted June 23, 2010 Posted June 23, 2010 Can't say I ever had any problems using viewports within my layouts. I must be lucky. Quote
