Lowest point of 3D Polyline
I made a surface and also made a 3D polyline of the surface boundary. I need to locate the lowest point of the 3D Polyline boundary. The polyline has over 100 vertices. Is there a way to query the highest and lowest point along a pline ??
Thanks!!
You can either extract the coordinates with vla-get-coordinates and combine the list into groups of 3 or entnext through the selected ename (using entsel), create a list of coordinates (X,Y,Z), sort by Z value, then you can easily take the highest and lowest value and label accordingly.
eg.
HighLowLabel.zipUnavailable
  • Thanks 1
Of course a visual way is to take a Front View and you would be able to see the lowest and the highest point. :D
Very true, it would just be a pain if there are points with 'close' elevations.
eg.
[ATTACH]21100[/ATTACH]
I'm not familiar with LISP. Do you know of a Lisp that will label the lowest point of a 3D Polyline ? or export a x,y,z file that can be sorted by elevation....as you have specified.
Thanks!!
Thanks!!
Ahh, what the hell. Attached in my original post.
You are the MAN!!
  envirocad said:
You are the MAN!!
Enjoy and you're welcome.
Oh yeah, and welcome to the forum. :)
