pBe Posted June 22, 2012 Posted June 22, 2012 You can apply it with locked layers? Will omit Dimensions in XRefs and on locked layers not included,wont be process, skip, ignore,.... Quote
Lee Mac Posted June 22, 2012 Posted June 22, 2012 You can apply it with locked layers? As stated and subsequently reiterated by pBe, not with the current code. To delete Dimensions on locked layers, the layers must first be unlocked, e.g.: (defun c:deldims ( / d l ) (setq d (vla-get-activedocument (vlax-get-acad-object))) (vlax-for a (vla-get-layers d) (if (eq :vlax-true (vla-get-lock a)) (progn (vla-put-lock a :vlax-false) (setq l (cons a l)) ) ) ) (vlax-for b (vla-get-blocks d) (if (eq :vlax-false (vla-get-isxref b)) (vlax-for o b (if (wcmatch (vla-get-objectname o) "AcDb*Dimension*") (vla-delete o) ) ) ) ) (foreach a l (vla-put-lock a :vlax-true)) (vla-regen d acallviewports) (princ) ) (vl-load-com) (princ) Quote
Guest jjorozco Posted June 22, 2012 Posted June 22, 2012 I see. There are still processes that do not quite understand. Thanks for the advices. Quote
