Madruga_SP Posted October 11, 2013 Posted October 11, 2013 Hi Marko_ribar Very kind of you interested in my task. I really appreciate your help. Thank you Quote
ymg3 Posted October 11, 2013 Posted October 11, 2013 Here it is with annotations now. New settings: annotreq 1 Annotation will be azimuth - distance, side by side. annotreq 2 Annotation will be azimuth / Distance on top of each other. annotreq nil Or anything else than 1 or 2, there will be no annotations. annoth (* txth 0.5) Heigth of Text for annotations. I've also added Marko's suggestion to make sure that the wipeouts are activated. It can also be affected by the TFRAMES toggle, you want it on otherwise the circles won't be showing. Next on the agenda will be translation of Titles and Prompts, and parameters for Text Colors in the table. ymg dt.LSP Quote
Madruga_SP Posted October 11, 2013 Posted October 11, 2013 (edited) I ask to myself "Now it's impossible the code is better" And everytime I see your update code I got a execellent surprised! Thank you very much!!!!! parameters for Text Colors in the table. I use just one kind of table configuration. (please see the attached file) Thank in advance. TABLE FORMAT.dwg Edited October 11, 2013 by Madruga_SP Quote
ymg3 Posted October 12, 2013 Posted October 12, 2013 There it is with an attempt at multi-language support. Right now I got English, French, Portuguese, Russian for Fixo, Serbian for Marko, and Spanish. I've modified the color support for the table text. However I could not come up with anything smarter than keeping the *cObj* *r* *g* and *b* global. One question for the vl wiz, Do I need to release the objects since they are put to nil upon completion of the routine. You start the routine by typing TD which stands for Technical Description. For Madruga_SP this updates does not bring you much, it may even be a regression for you as some of the titles are different than yours. I will try to address the table line colors and putting having numbers according to your format 00 - 01, 01 - 02 etc. ymg td.LSP Quote
ymg3 Posted October 12, 2013 Posted October 12, 2013 Madruga_SP, Here I've implemented padding for the station numbers. For this there is a new setting padcar which you set to "0" for your case, if you set padcar to """ there will be no padding. You could also use " " a space so that everything align. ymg td.LSP Quote
Madruga_SP Posted October 14, 2013 Posted October 14, 2013 Hi ymg How have you been? Thank you very much! The code is amazing, doing everything I need. Worked like a charm. I've been looking for that code for a long time and you made my wish come true. Thank you, ymg Best Regards Quote
notview Posted October 23, 2013 Posted October 23, 2013 Can not read if the direction are DUE EAST, DUE WEST, DUE NORTH, or DUE SOUTH. Quote
ymg3 Posted October 24, 2013 Posted October 24, 2013 Can not read if the direction are DUE EAST, DUE WEST, DUE NORTH, or DUE SOUTH. It does work here, or I don't understand when youy direction are Due East. Here attached a small modif. which let you vary the numbers of sides of the wipeouts, thus you can have Triangle, Square......n-sided polygon as your wipeouts on the vertices by varying parameters woside in the setting section. td.LSP Quote
Madruga_SP Posted November 22, 2013 Posted November 22, 2013 Hi ymg, How are you? Thank you very much! The code is helping me a lot. I need the code verify arc lenght and radius. Could you help me, please? Have a nice weekend! RADIUS.dwg Quote
ymg3 Posted November 23, 2013 Posted November 23, 2013 There U go with radius and arc distance. I still have not fixed the annotations around the polyline, will do it later. However the list should be OK. ymg tdradius.LSP Quote
Madruga_SP Posted November 25, 2013 Posted November 25, 2013 Thank you for replay my friend, Your code is exactly I was wanted to. But I've already did some modifications in your code and I couldn't add radius and arc distance in my code. Could you help me add radius and arc distance in the code bellow, please?? Is it possible change the decimal separator to comma?? Because in Brazil we use comma instead of period. Thank you very much, again! td-radius.LSP Quote
ymg3 Posted November 25, 2013 Posted November 25, 2013 Madruga_SP, There u go! (Você está se tornando um pouco preguiçoso ...) ymg tdradius.LSP Quote
Madruga_SP Posted November 25, 2013 Posted November 25, 2013 Hi, Sorry to bother you, my friend... (Você está se tornando um pouco preguiçoso ...) "Eu ainda sou iniciante em autolips, estou aprendendo..." I'm learning about lisp, there are some tutorials in youtube (portuguese) and I'm watching. Thank God there are people like you... Many Thank you Quote
leo321 Posted October 4, 2017 Posted October 4, 2017 To Be perfect inset column Coordanetes E, N Quote
maninilip Posted August 31, 2020 Posted August 31, 2020 On 6/19/2010 at 4:44 PM, fixo said: Try this one (quick and dirty though) (vl-load-com) (defun C:Bearings (/ *error* acsp ang atable cnt col dist item osm point_list pt row table_data tmp tmp_data) (defun *error* (msg) (if (and msg (not (member msg '("console break" "Function cancelled" "quit / exit abort")))) (princ (strcat "\nError: " msg)) ) (if osm (setvar "osmode" osm)) (princ) ) (setq osm (getvar "osmode")) (setvar "osmode" 1) (setq cnt 1) (while (setq pt (getpoint (strcat "\n >> Specify point #" (itoa cnt) " by order (hit Enter to exit) >> "))) (setq point_list (cons pt point_list) cnt (1+ cnt)) ) (setq point_list (reverse point_list)) (setq cnt 0) (while (<= cnt (- (length point_list) 2)) (setq tmp (list (strcat (itoa (1+ cnt)) " - " (itoa (+ cnt 2))) (nth cnt point_list) (nth (1+ cnt) point_list)) tmp_data (cons tmp tmp_data) ) (setq cnt (1+ cnt)) ) (setq tmp (list (strcat (itoa (length point_list)) " - 1") (last point_list) (car point_list)) tmp_data (cons tmp tmp_data) ) (setq tmp_data (reverse tmp_data)) (foreach item tmp_data (setq ang (angle (cadr item) (caddr item))) (setq ang (angtos ang 4 4)) (setq dist (distance (cadr item) (caddr item))) (setq dist (strcat (rtos dist 2 2) " m.")) (setq tmp (list (car item) ang dist)) (setq table_data (cons tmp table_data)) ) (setq table_data (reverse table_data)) (setq pt (getpoint "\n >> Specify insertion point >> ")) (setq acsp (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object)))) ) (setq atable (vlax-invoke acsp 'AddTable pt (+ 2 (length table_data)) (length (car table_data)) (* (getvar "textsize") 2.0) (* (getvar "textsize") 15)) ) (vla-put-regeneratetablesuppressed atable :vlax-true) (vla-settextheight atable actitlerow (getvar "textsize")) (vla-settextheight atable acheaderrow (getvar "textsize")) (vla-settextheight atable acdatarow (getvar "textsize")) (vla-put-vertcellmargin atable (/ (getvar "textsize") 4.25)) (vla-settext atable 0 0 "TECHNICAL DESCRIPTIONS") (vla-settext atable 1 0 "LINES") (vla-settext atable 1 1 "BEARINGS") (vla-settext atable 1 2 "DISTANCES") (setq row 2) (foreach item table_data (setq col 0) (foreach x item (vla-settext atable row col x) (vla-setcellalignment atable row col acMiddleCenter) (setq col (1+ col))) (setq row (1+ row)) ) (vla-put-regeneratetablesuppressed atable :vlax-false) (*error* nil) (princ) ) ~'J'~ Good day, ive been looking for this specific lisp for over a year already. dont know why i didnt find this sooner. Really thankful to Mr. Fixo. youre a lifesaver. I was wondering, what can i change to make in this code to make the output table looks like (attached photo) Thank you! Quote
BIGAL Posted August 31, 2020 Posted August 31, 2020 (edited) If you do a bit of research about tables (+ 3 (length table_data)) will add a extra row (vla-settext atable 1 0 "LINES") (vla-settext atable 1 1 "BEARINGS") (vla-settext atable 1 2 "DISTANCES") (vla-settext atable 2 0 "LOT ACTUAL SURVEY") note also need to increase start row for brg-dist (setq row 2) now (setq row 3) Your homework is (vla-mergecells atable rowmin rowmax colmin colmax x)) A lot of us have aknowledged help from FIXO he will be missed. Edited August 31, 2020 by BIGAL Quote
