Generate Bearings & Distances into table
as shown in figure..
please help us
thank you.
  • Replies 75
  • Madruga_SP
    22
  • ymg3
    14
  • fixo
    9
  • alanjt
    8
Posted Images
You can do this is Land Desktop and Civil 3D.
please help us
thank you.
Try this one (quick and dirty though)
(vl-load-com)
(defun C:Bearings (/ *error* acsp ang atable cnt col dist item osm
     point_list pt row table_data tmp tmp_data)
  (defun *error*  (msg)
    (if (and msg
      (not
        (member msg
         '("console break" "Function cancelled" "quit / exit abort"))))
    (if osm
      (setvar "osmode" osm))
(setq osm (getvar "osmode"))
(setvar "osmode" 1)
(setq cnt 1)
(while (setq pt (getpoint
    (strcat "\n  >> Specify point #"
     (itoa cnt)
     " by order (hit Enter to exit) >> ")))
  (setq point_list (cons pt point_list)
 cnt    (1+ cnt))
(setq point_list (reverse point_list))
(setq cnt 0)
(while (<= cnt (- (length point_list) 2))
  (setq tmp  (list (strcat (itoa (1+ cnt)) " - " (itoa (+ cnt 2)))
         (nth cnt point_list)
         (nth (1+ cnt) point_list))
 tmp_data (cons tmp tmp_data)
  (setq cnt (1+ cnt))
(setq tmp      (list (strcat (itoa (length point_list)) " - 1")
       (last point_list)
       (car point_list))
(setq tmp_data (reverse tmp_data))
(foreach item  tmp_data
  (setq ang (angle (cadr item) (caddr item)))
  (setq ang (angtos ang 4 4))
  (setq dist (distance (cadr item) (caddr item)))
  (setq dist (strcat (rtos dist 2 2) " m."))
  (setq tmp (list (car item) ang dist))
  (setq table_data (cons tmp table_data))
(setq table_data (reverse table_data))
(setq pt (getpoint "\n  >> Specify insertion point >> "))
(setq acsp (vla-get-block
      (vla-get-activelayout
        (vla-get-activedocument
   (vlax-get-acad-object))))
(setq atable
       (vlax-invoke
  acsp
  'AddTable
  pt
  (+ 2 (length table_data))
  (length (car table_data))
  (* (getvar "textsize") 2.0)
  (* (getvar "textsize") 15))
(vla-put-regeneratetablesuppressed atable :vlax-true)
(vla-settextheight atable actitlerow (getvar "textsize"))
(vla-settextheight atable acheaderrow (getvar "textsize"))
(vla-settextheight atable acdatarow (getvar "textsize"))
(vla-put-vertcellmargin atable (/ (getvar "textsize") 4.25))
(vla-settext atable 0 0 "TECHNICAL DESCRIPTIONS")
(vla-settext atable 1 0 "LINES")
(vla-settext atable 1 1 "BEARINGS")
(vla-settext atable 1 2 "DISTANCES")
(setq row 2)
(foreach item  table_data
  (setq col 0)
  (foreach x  item
    (vla-settext atable row col x)
    (vla-setcellalignment atable row col acMiddleCenter)
    (setq col (1+ col)))
  (setq row (1+ row))
  (vla-put-regeneratetablesuppressed atable :vlax-false)
  (*error* nil)
~'J'~
(vl-load-com)
    (if (and msg
      (not
        (member msg
    (if osm
(setvar "osmode" 1)
(setq cnt 1)
     (itoa cnt)
 cnt    (1+ cnt))
(setq cnt 0)
  (setq cnt (1+ cnt))
       (last point_list)
       (car point_list))
(setq atable
       (vlax-invoke
  acsp
  'AddTable
  pt
(setq row 2)
  (setq col 0)
  (foreach x  item
  (setq row (1+ row))
  (*error* nil)
~'J'~
This is great !!! why does Acad insist on putting the "d" in the bearing angle instead of chr alt 248 (degree symbol) ?
Is there a way to program the degree symbol ? into the bearing instead of "d" ?
If not, one can always edit the table line by line...
Thanks for super program for those who do not have civil add on.
S
Substitute
for
(setq ang (vl-string-subst "°" "d" (angtos ang 4 4)))
will give you the degrees symbol
SF
Substitute
for
SF
Thanks, it's much easier that I've thought :)
~'J'~
I have modified it some more, so that the end result is easier to read.
If minutes and/or seconds are under 10 then a zero has been added to the bearing string.
hope that's useful
SF
(vl-load-com)
             degreeloc minuteloc secondloc AngString)
    (if (and msg
      (not
        (member msg
    (if osm
(setvar "osmode" 1)
(setq cnt 1)
     (itoa cnt)
 cnt    (1+ cnt))
(setq cnt 0)
  (setq cnt (1+ cnt))
       (last point_list)
       (car point_list))
(setq ang (angtos(angle (cadr item) (caddr item))4 4)
      degreeloc (vl-string-position (ascii "d") ang);location of "d"
      minuteloc (vl-string-position (ascii "'") ang);location of '
      secondloc (vl-string-position (ascii "\"") ang);location of "
);setq
(if (= (- minuteloc degreeloc) 2)
(setq ang (vl-string-subst "d0" "d" ang));add 0 for seconds under 10
);if
(if (= (- secondloc minuteloc) 2)
(setq ang (vl-string-subst "'0" "'" ang));add 0 for minutes under 10
);if
(setq AngString (vl-string-subst "°" "d" ang);Substitute degree symbol
      tmp (list (car item) AngString dist)
);setq
);foreach
(setq
       acsp (vla-get-block
      atable (vlax-invoke acsp 'AddTable pt
);setq
(setq row 2)
  (setq col 0)
  (foreach x  item
  (setq row (1+ row))
  (*error* nil)
hope that's useful
SF
(vl-load-com)
    (if (and msg
      (not
        (member msg
    (if osm
(setvar "osmode" 1)
(setq cnt 1)
     (itoa cnt)
 cnt    (1+ cnt))
(setq cnt 0)
  (setq cnt (1+ cnt))
       (last point_list)
       (car point_list))
);setq
);if
);if
);setq
);foreach
(setq
       acsp (vla-get-block
);setq
(setq row 2)
  (setq col 0)
  (foreach x  item
  (setq row (1+ row))
  (*error* nil)
thank you so much..
:shock:
hope that's useful
SF
(vl-load-com)
    (if (and msg
      (not
        (member msg
    (if osm
(setvar "osmode" 1)
(setq cnt 1)
     (itoa cnt)
 cnt    (1+ cnt))
(setq cnt 0)
  (setq cnt (1+ cnt))
       (last point_list)
       (car point_list))
);setq
);if
);if
);setq
);foreach
(setq
       acsp (vla-get-block
);setq
(setq row 2)
  (setq col 0)
  (foreach x  item
  (setq row (1+ row))
  (*error* nil)
once again thank you..another little favor could you please modified this lisp.."remove the seconds" as shown in the figure in my first post.
thanks and "HAPPY FATHER'S DAY"
I'll say it once more then keep my mouth shut: You can do this very thing from core LDD and/or C3D and it's a lot easier.
Try this - without seconds
check out angtos function
you can adjust the the two numbers at the end of this line
for a different format.
(setq ang (angtos(angle (cadr item) (caddr item))4 2);precision 2 - ;minutes only
updated code-
(vl-load-com)
    (if (and msg
      (not
        (member msg
    (if osm
(setvar "osmode" 1)
(setq cnt 1)
     (itoa cnt)
 cnt    (1+ cnt))
(setq cnt 0)
  (setq cnt (1+ cnt))
       (last point_list)
       (car point_list))
(setq ang (angtos(angle (cadr item) (caddr item))4 2);precision 2 - minutes only
;;;       secondloc (vl-string-position (ascii "\"") ang);location of "
);setq
);if
;;; (if (= (- secondloc minuteloc) 2)
;;; (setq ang (vl-string-subst "'0" "'" ang));add 0 for minutes under 10
;;; );if
);setq
);foreach
(setq
       acsp (vla-get-block
);setq
(setq row 2)
  (setq col 0)
  (foreach x  item
  (setq row (1+ row))
  (*error* nil)
But Alan not all of us have LDD and/or C3D.
Does LDD/C3D cost a lot more than Vanilla CAD? Just curious
True, but the OP (oliver) has LDD.
Much much more. All the addon version of cad are a lot more expensive. I think C3D is around $6000.
Woww... I never realised that! :shock:
I think vanilla is around $3000.
They're all AutoCAD, just with lots of extras.
Your close, More like $3,995 US dollars just for vanilla.
Ahh, OK. The last time I worked anywhere that used Vanilla AutoCAD, I was 18 and it was r2000.
