anaok Posted June 17, 2010 Posted June 17, 2010 Hi guys I am using VRayPhysicalCamera for the first time. when I used the standard camera,I had no problems becouse the picture was good but when I used the VRayPhysicalCamera , the picture had has a lot of light dots can you help me how to get rid of light dots ? I used autocad 2010 , 3ds max 2010 , Vray 1.5 sp5 to make this picture. Thank you Quote
Cad64 Posted June 17, 2010 Posted June 17, 2010 I don't use Vray, so I can't really say what might be causing this, but if you Google this problem you will find many possible solutions. Quote
minks Posted June 17, 2010 Posted June 17, 2010 well physical camera can be pain if your not familiar with basics of real life photography (aperature, f-stop etc). also bare in mind that vray lights behave diferentlly when using P-camera. im guessing you placed a camera in front of the glass, so you should check your refraction subbdivision for the glass, (take it up to 20 or so), post your gi settings (light cashe and iridiance map settings). and if your getting good resaults with normal camera i see no reason to bother with physical camera, it does give you more freedom but as said if your not verry good with real life photography it just adds more complications to your rendering setup. cheers Quote
Exelweb Posted June 23, 2010 Posted June 23, 2010 OMG your work is very good. Keep it up. You have done a tremendous job. I do not much about this but i think you can heal the dots in photoshop i guess. Quote
Cad64 Posted June 23, 2010 Posted June 23, 2010 I do not much about this but i think you can heal the dots in photoshop i guess. No, it's a problem with the render settings. Fixing this image in Photoshop would take ages. Quote
anaok Posted June 26, 2010 Author Posted June 26, 2010 Hi all Sorry . I did not reply quickly cuz I was busy Thanks Quote
anaok Posted June 26, 2010 Author Posted June 26, 2010 OMG your work is very good. Keep it up. You have done a tremendous job. I do not much about this but i think you can heal the dots in photoshop i guess. Thank you very much for your encouragement :) Quote
anaok Posted June 26, 2010 Author Posted June 26, 2010 No, it's a problem with the render settings. Fixing this image in Photoshop would take ages. The problem was solved, you were right the problem was with the render settings. check "sub pixel mapping" on the color mapping tab. (Note: when I turn sub-pixel mapping on only , I got rid of light dots) If anyone wants more information open this link http://forums.cgarchitect.com/28616-white-dots-my-vray-rendering-help.html V-Ray for 3ds Max official help index http://www.spot3d.com/ Tnak you. Quote
anaok Posted June 26, 2010 Author Posted June 26, 2010 well physical camera can be pain if your not familiar with basics of real life photography (aperature, f-stop etc). also bare in mind that vray lights behave diferentlly when using P-camera. im guessing you placed a camera in front of the glass, so you should check your refraction subbdivision for the glass, (take it up to 20 or so), post your gi settings (light cashe and iridiance map settings). and if your getting good resaults with normal camera i see no reason to bother with physical camera, it does give you more freedom but as said if your not verry good with real life photography it just adds more complications to your rendering setup. cheers Hi minks thank you for reply you are right that I put a camera in front of the glass, but I did everything you said for glass before I read your reply. I think that made glass with wrong reflection and refraction setting like (IOR , color selector I want to learn how to create vray glass well . I found tutorials (V-RAY MATERIAL SETTINGS , Rendering Glass and Liquid) *.pdf by author Wouter Wynen These tutorials can be found : under (Chaos Group) http://commerce.vismasters.com/download/view/type/?dtid=2 (*.pdf , zip) or http://designmeet.com/index2.php?option=com_docman&task=doc_view&gid=20&Itemid=44 http://st.free-lance.ru/users/Zelen/upload/f_496fa34f84716.pdf I agree with you that physical camera can be pain if we do not know basics of real life photography. Quote
