terry01 Posted June 15, 2010 Posted June 15, 2010 Greetings to all you gurus here:D. I trying to produce a cross section here based on field books. manage to do the line. Is there any lisp to automatically create the text that show levels & offsets from CL by just clicking on the green line. a picture can tell a thousand words. pls see the pics. Thanks in advance Quote
BIGAL Posted June 16, 2010 Posted June 16, 2010 A question and an answer are the cross section being created using another program ? Could it be changed to auto add extra values. Answer here is a copy of surfaceRl just copy a existing text level across to the new vertical line run SRL it works out the answer graphically not from the adjoining values we found its within 2-3mm of computed value bit dependant on scale. Could be modified also to change offset value. ;Calculates level of a point in cross or long sections (setvar "cmdecho" 0) (princ "\n To run just type SRL") ;(defun c:SRL () (if (= dwgscale nil) (setq dwgscale (/ 1000.0 (getreal "\n enter vertical scale "))) ) (setq datum (getreal "\n Enter datum level -ve to reset vert scale ")) (if ( < datum 0.0) (progn (setq dwgscale (/ 1000.0 (getreal "\n enter vertical scale "))) (setq datum (getreal "\n Enter datum level ")) ) ) (setq test 1) (while (= test 1) (setq pt1 (getpoint "\npick datum")) (setq pt2 (getpoint "\npick point")) (setq dist (/(distance pt1 pt2) dwgscale)) (setq en1 (car (entsel "\nSelect text number:" ))) (if (/= en1 nil) (progn (setq tent (entget en1)) (setq a (+ dist datum)) (setq a (rtos a 2 3)) (setq el (subst (cons 1 a) (assoc 1 tent) tent)) (entmod el) );progn (princ "\nplease pick again"); else );if ); while t (setq el nil) (setq en nil) (setq a nil) (setq v1 nil) (setvar "cmdecho" 1) (princ) ;ends main defun Quote
terry01 Posted June 16, 2010 Author Posted June 16, 2010 Many thanks BIGAL:D, Yes, the cross sections were produce using a Land Desktop 2k. I can produce a cross section but it only generates the centre line levels only. any idea on how to overcome this? many thanks in advance. however, there is a few works that I had to manually input the survey details into CAD. your PROGRAM really saves me a lot of time:shock: again many thanks Quote
