I am trying to incoporate this command (setbylayer) into a lisp routine that I am making to clean up our xrefs. I am trying to adjust the settings to change only the color, select all objects in the drawing, change byblock to bylayer, and to include blocks. Any help would be appreciated.
For starters you could look into SETBYLAYERMODE variable.
SETBYLAYERMODE
Type: Integer
Saved in: Registry
Initial value: 127
From the AutoCAD Help Section under system variables.
Controls which properties are selected for SETBYLAYER
The setting is stored as an integer using the sum of the following values:
0 No properties are selected
1 Color property
2 Linetype property
4 Lineweight property
8 Material property
16 Plot Style property
32 Changes ByBlock to Bylayer
64 Includes blocks when changing ByBlock to ByLayer
There is also other information there not shown here.
Also look into ssget in the Developer Help Section
Creates a selection set from the selected object
(ssget [sel-method] [pt1 [pt2]]
[pt-list] [filter-list])
Selection sets can contain objects from both paper and model space, but when the selection set is used in an operation, ssget filters out objects from the space not currently in effect. Selection sets returned by ssget contain main entities only (no attributes or polyline vertices).
Maybe this thread will give you some idea:http://www.cadtutor.net/forum/showthread.php?t=42062&highlight=SET+BYLAYER+LISP
How is this. (FYI - I am a novice at this stuff)
(defun c:cleanxref2 ()
  (command "setvar" "cmdecho" 0)(command "setbylayermode" "1")
  (command "setvar" "cmdecho" 0)(command "setbylayer" "all" "" "y" "y")(princ))
The setbylayer command doesn't seem to get dimensions that have the text set to a different color. Is there a setting in this command that can access all annotation items in a drawings as well as all the other items this command is changing to bylayer?
That because its part of a named dimstyle. In that case you would need to get a selection set of all dimensions and change the dimstyle variables of the named dimstyle to bylayer. Seems you will have some addtional coding to do.
Dimension Text: DIMCLRT
Dimension Lines: DIMCLRD
Dimension Ext Lines: DIMCLRE
ksperopoulos,
Below is a code that I found on Afralisp http://www.afralisp.net/archive/lisp/clay.htm that touches the subject of setting entities color properties to bylayer. There are other areas such as linetype and blocks to give you a better idea on how to proceed. Once you get the idea with this code, The rest should become easier I hope. Afralisp has a great way of explaining things in simple terms to make it easier to learn. For linetypes and blocks you can find coding on Afralisp as well. You can refine them to your need as you see fit.
This code deals with setting color on most general entities.
I just changed the long name from ColorToLayer.lsp to CTL.lsp.
;CODING BEGINS HERE
(defun c:CTL ()
 (setq i 0 n 0)                                            ;clear the loop control variables
 (prompt "\n Select entities to analyze ")                 ;prompt the user
 (setq sel (ssget))                                        ;get the selection set
 (setq n (sslength sel))                                   ;get the number of objects
 (repeat n                                                 ;start the loop
   (setq entity (ssname sel i))                            ;get the entity name
   (setq name (entget entity))                             ;now get the entity list
   (if (not (assoc 6 name))                                ;if not Bylayer
     (progn                                                ;do the following
       (setq layer (cdr (assoc 8 name)))                   ;retrieve the layer name
       (setq layerinf (tblsearch "LAYER" layer))           ;get the layer data
       (setq layercol (cdr (assoc 62 layerinf)))           ;extract the default layer colour
       (setq name (append name (list (cons 62 layercol)))) ;construct an append the new list
       (entmod name)                                       ;update the entity
       (entupd entity)                                     ;update the screen
     )                                                     ;progn
   )                                                       ;if
   (setq i (1+ i))                                         ;increment the counter
 )                                                         ;repeat
 (princ))                                                  ;defun
;CODING END HERE
Thanks Buzzard! I've got a lot to learn.
  • 13 years later...
How would you write this if you wanted to do it on multiple files within the same folder?
You can write a SCRIPT that will open a dwg and run the 2 lines then close and save. A script is like writing down the commands that you manually type but can have lisp. Save script as a .scr file.
Not tested.
Open dwg1
close y
Open dwg2
close y
Open dwg3
close y
Dont worry about cmdecho as screen will flash anyway.
Google Running scripts autocad
Edited by BIGAL
