seth007 Posted June 3, 2010 Posted June 3, 2010 Ok, I gave it a try. I'm having a problem: On running this code it gives me the error it cand find the library: 'set to uppercase FilterStr = StrConv(ObjType, vbUpperCase) ObjectStr = StrConv(objEnt.ObjectName, vbUpperCase) ObjectStr2 = ObjectStr ObjectStr = Mid(ObjectStr, InStr(1, ObjectStr, "DB", 1) + 2) I'm not used to vba, (I like vbnet or C#) Do I need a reference here, an import or using, that points to that library? Quote
scj Posted June 5, 2010 Posted June 5, 2010 Some times ago I made my version of Offset3d.lsp Regards Jochen offset3d.lsp Quote
seth007 Posted June 8, 2010 Posted June 8, 2010 Some times ago I made my version of Offset3d.lspRegards Jochen this works like a charm, thanks Quote
CarlosBZ Posted January 7, 2011 Posted January 7, 2011 Very useful. Thank you very much for sharing. Quote
Tyke Posted January 7, 2011 Posted January 7, 2011 For people with AutoCAD Civil 3D there is a native 3D offset command _AeccOffsetFeature which is the 3D offset command. Quote
John1951 Posted February 12, 2015 Posted February 12, 2015 To make this work I made a form with a command button and 2 text boxes, textboxZ and textboxV. I added this code to the command_click event of the command button: Private Sub CommandButton1_Click() Dim picked3dPoly As Acad3DPolyline Dim old3dPoly As Acad3DPolyline ' Begin the selection Dim returnObj As AcadObject Dim basePnt As Variant On Error Resume Next ' The following example waits for a selection from the user RETRY: ThisDrawing.Utility.GetEntity returnObj, basePnt, "Select a 3D Polyline object" If Err 0 Then Err.Clear MsgBox "Program ended.", , "GetEntity Example" Exit Sub Else returnObj.Update If (returnObj.EntityName = "AcDb3dPolyline") Then Set picked3dPoly = returnObj z# = Val(TextBoxZ.Text) h# = Val(TextBoxH.Text) Call Offset3dPoly(picked3dPoly, h#, z#, "0", old3dPoly) returnObj.Update Else GoTo RETRY End If End If GoTo RETRY End Sub Quote
John1951 Posted February 12, 2015 Posted February 12, 2015 Forgot to add that the Offset3dPoly subroutine code must be added to the General section of the form code Quote
Lippens Infra Posted November 20, 2020 Posted November 20, 2020 On 6/5/2010 at 2:47 PM, scj said: Some times ago I made my version of Offset3d.lsp Regards Jochen offset3d.lsp 4.48 kB · 325 downloads This works, but the Z-values of the points are not the same at every point. I have the example in attachment. Anyone has an update/hotfix/... Thanks a lot offset3d.dwg Quote
ammobake Posted November 21, 2020 Posted November 21, 2020 There may also be an app in the autodesk app store that may be able to perform this function. But as someone mentioned before, save for using lisp routines or add-ons, this kind of offset in vanilla Autocad won't work. I guess my question is why are you offsetting - are you intending to turn a 3d polyline into a cylindrical object (like offsetting from the center of the 3dpolyline) or are you offsetting in one direction from the source in 3d space? Offsetting as a polyline and then converting that polyline to a 3d polyine is a sound alternative just depending on what outcome you are looking for and what drawing/geometry you are dealing with. One could then rotate the object and/or tweak the nodes of the 3d polyline to adjust their positions, manually. In most cases when u are dealing with 3d solids or meshes it is imperitive to think of your precursors in a coplanar context, first, since those objects are needed to either extrude to a 3d solid or to apply a rulesurf, edgesurf, or loft command (though loft will work on open plines and splines). You can always rotate those objects in 3d space before extruding or adding meshes but the source geometry would still be coplanar. So working in 3D is always a matter of working out in your brain what you'll need to do for step1, step2, step3, etc... and planning out those actions beforehand to achieve a desired outcome. There is a tool on the autodesk app store that can offset splines - but it is unclear if it works on splines with 3d geometry and my gut sais that's likely a "no". (A quadratic spline is basically just a parabola because it is always coplanar but cubic splines can twist in 3d space because they are not). Offset command in autocad only works on planar lines, splines and polylines though. It is possible to use LISP commands to emulate what a 3d polyline offset might look like - by analyzing the geometry of the source object and performing more of copy/paste type function where the offset is in a specific direction in 3d space from the source point at a specified distance (though there are other tricks one could program). -ChriS Quote
Joe Kycek Posted November 26, 2020 Posted November 26, 2020 I recently received an email about this post 11 years later; in 2020. 'seth007' had posted that the code crashed; which I missed; so I did not follow up. 'ammobake' had posted about 3d poly offsets which must have prompted the email. Anyway, I looked into it; and the error was caused by a civil 3d reference in the vba project. Back then, I was working with civil 3d objects and code; and evidently left civil 3d references in the project. Sorry bout' that. Not sure why the vba 'StrConv' function would crash with civil 3d references in the project, but when I removed the civil 3d references, StrConv worked as usual. I tested the code in vanilla autocad 2010 and autocad 2020 and it works. So I am uploading the new version. Offset3dPoly.dvb Quote
