sandiegophil Posted June 10, 2010 Posted June 10, 2010 Hello, Would anyone please share their best method for converting a survey figure to an alignment. Any help and/or input is greatly appreciated. Thanks, Phil Quote
BIGAL Posted June 11, 2010 Posted June 11, 2010 Not sure what you mean survey figure but just turn objects into a polyline, "Alignments from polyline" Quote
sinc Posted June 11, 2010 Posted June 11, 2010 The best method I know of requires third-party help, but can simultaneously create both an Alignment and Profile without destroying the Survey Figure: http://www.quuxsoft.com/SincpacC3D_Help/SP_CreateAlignmentProfileFeatureLine.htm Quote
sandiegophil Posted June 11, 2010 Author Posted June 11, 2010 thank you both for the input, much appreciated. Phil Quote
BIGAL Posted June 21, 2010 Posted June 21, 2010 Sorry Sinc but just un tick the box erase objects when creating an alignment ? Leaves original objects behind. Quote
sinc Posted June 21, 2010 Posted June 21, 2010 Al - have you tried to select a Survey Figure when running "Create Alignment from Objects"? Quote
sandiegophil Posted June 21, 2010 Author Posted June 21, 2010 Thank you all for your input and suggestions, I greatly appreciate it. Phil Quote
