shedokan Posted June 7, 2010 Posted June 7, 2010 Hello, I wanted to ask if there is a way to create a mesh using two faces, I have no idea on how to do this since I'm new to autocad but in other 3d programs I have used this kind of thing is usually called "fill". I'll appreciate any help with this, Thanks Quote
rvpas Posted June 7, 2010 Posted June 7, 2010 Hi, What you mean "mesh using two faces" ? do you have an exemple Quote
shedokan Posted June 7, 2010 Author Posted June 7, 2010 I mean something like if I have two circle faces a meter a part and I want to create a cylinder from them, straight faces between the edge f one face o the egde of the other face. In my case instead of two circle faced I have two Identical faces that were made of a path. Quote
shedokan Posted June 7, 2010 Author Posted June 7, 2010 I have tried the loft tool but in place of the two faces it displays holes in the shapes of the faces, what I ask is something to use the faces and create a mesh but will leave the two faces as part of the mesh. do you want me to upload images about what I am talking about? Thanks Quote
shedokan Posted June 7, 2010 Author Posted June 7, 2010 Sorry, I can't do it right now but as soon as I'll get to my working computer I will. But what I think I found out how to do this, I have drawn a line from one surface to the other and then used "tabulated surface" since they are exactly the same but the only problem I have now is that the mesh that's been created is very rough on the edges(squarish) is there a way to make it more smooth and more like my first face? Thanks Quote
