Guest kruuger
Hello
I create a simple lisp routine to freeze required layer in viewport. Everything works fine but when we got a lot of layers and xref's programs not works to fast. sometimes it takes more then 10sec to finish.
Is there any way to speed up this routine? Change some functions, maybe do this in completely different way?
Any ideas?
thanks
kruuger
Scale VP.lsp
  • Replies 37
  • alanjt
    12
  • Lee Mac
    6
  • Se7en
    2
  • MSasu
    1
Try to access layer's associated lists and modify parameters instead of using command function.
Regards,
Guest kruuger
Regards,
hmm, i'm not sure if i understood you correct?
do you mean (vla-put-freeze aNewLayer :vlax-true)?
i think i can't use this because it freeze layer in drawings not in selected vport.
I try also with XDATA code 1003 for vport, but entmode can't update the viewport.
kruuger
If you are stuck with command, put the layers into a comma delimited string so you only have to execute VPLayer once.
Guest kruuger
i'm not sure this will help because i want to freeze all layers *dims* and *text* (use mask for that).
krugger
krugger
Then use "*dims*,*text*"
Guest kruuger
aaa like this...
i will try this tomorrow at work.
thanks
kruuger
aaa like this...
thanks
kruuger
Good luck.:wink:
Guest kruuger
oo yes, it works faster.
but i noticed one thing. at beginning i freeze these layers:
"*DIM*,*TEXT_*,A-HAT1*,*veneer*"
after that i restore, for example for scale 3" layer *veneer*. restoring takes a lot of time so...
my idea is only to freeze and not restore. but how to not freeze, for example for scale 16 layer *DIM16*,*TEXT_16?
is it possible to do this with wcmatch? (freeze *DIM* but exclude *DIM16*)
thanks
kruuger
Try something like this:
(defun _LayerFilter (include exclude / d s)
 ;; include - filter string to include matching ("" if not needed)
 ;; exclude - filter string to exclude matching ("" if not needed)
 ;; Alan J. Thompson
 (while (setq d (tblnext "layer" (null d)))
   (if (and (wcmatch (setq d (strcase (cdr (assoc 2 d)))) (strcase include))
            (not (wcmatch (strcase d) (strcase exclude)))
     (if s
       (setq s (strcat s "," d))
       (setq s d)
 s
eg.
(_layerfilter "*dim*" "*dim16*")
Guest kruuger
Alan your code works perfect. now wihtout restoring layers lisp should work very fast.
thank you,
kruuger
thank you,
kruuger
You're welcome. Enjoy. :)
Maybe someone can help you incorporate something along the lines of entmod or vla-put-freeze so you dont have to use command at all (not that command is bad; I use it quite a bit myself)...you know, for fun.
Here is a small (funny *lol*) example of how you can freeze the current layer using entmod by just quickly flipping a bit.
( (lambda ( / laylst )
  (setq laylst (entget (tblobjname "LAYER" (getvar 'CLAYER))))
  (entmod
   (subst
    (cons 70 (boole 6 (cdr (assoc 70 laylst)) 1))
    (assoc 70 laylst)
    laylst))) )
Nice one Se7en, this is what I had:
;; Freeze/Thaw Layer  ~  Lee Mac
;; layer - layer table object (tblobjname)
;; freeze - 1 = Freeze Layer
;;          0 = Thaw Layer
(defun FTLayer ( layer freeze / dx70 el )
 (setq dx70 (cdr (assoc 70 (setq el (entget layer)))))
 (entmod
   (subst
     (cons 70 (boole (+ 4 (* freeze 3)) 1 dx70)) (assoc 70 el) el)))
*smile* Also very nice.
Too bad I only have one more trick up my sleeve.
What if we improve the argument handling ability of our little concoction?
;; Argument:
;;          t or non nil: thaw, or leave thawn
;;          0 or false: freeze, or leave frozen
;;          Any value except 0 = true
(cond ((= 0 argument) 7) (argument 2) (7))
(defun frlay ( argument / laylst )
  ;; Argument:
  (entmod
   (subst
    (cons 70 (boole (cond ((= 0 argument) 7) (argument 2) (7)) (cdr (assoc 70 laylst)) 1))
    (assoc 70 laylst)
    laylst)))
Guest kruuger
Se7en, Lee
Please noticed that my goal was to freeze layer thru viewport.
Only way i know is vplayer.
kruuger
Try this Kruuger:
;; Freeze Layer in Viewport (Lee Mac)
;; Arguments:
;; layername [sTR]  ~  valid Layer Name
;; flag      [iNT]  ~  1 = freeze in vp
;;                     0 = thaw in vp
(defun FreezeInViewport ( layername flag )
 ;; © Lee Mac  ~  20.06.10
   (lambda ( object )
     (if object
       (entmod
         (subst
           (cons 70
             (boole (+ (* flag 5) 2)
               (cdr
                 (assoc 70
                   (entget object)
               2
           (assoc 70 (entget object))
           (entget object)
   (tblobjname "LAYER" layername)
Guest kruuger
Try this Kruuger:
;; Arguments:
;; layername [sTR]  ~  valid Layer Name [sTR]
;;                     0 = thaw in vp
   (lambda ( object )
     (if object
       (entmod
         (subst
           (cons 70
               (cdr
                 (assoc 70
                   (entget object)
               2
           (entget object)
hmm, nothing happen. is missing something for object?
kruuger
Guest kruuger
return:
Command: (FREEZEINVIEWPORT "DRAWER3" 0)
((-1 . <Entity name: 7c7bb798>) (0 . "LAYER") (330 . <Entity name: 7ec41c10>)
(5 . "2B23") (100 . "AcDbSymbolTableRecord") (100 . "AcDbLayerTableRecord") (2
. "DRAWER3") (70 . 0) (62 . 3) (6 . "Continuous") (290 . 1) (370 . -3) (390 .
<Entity name: 7ec41c78>) (347 . <Entity name: 7ec41f00>))
Command: (FREEZEINVIEWPORT "DRAWER3" 1)
. "DRAWER3") (70 . 2) (62 . 3) (6 . "Continuous") (290 . 1) (370 . -3) (390 .
any difference is for code 70.
k.
