I´m creatig points with Manual point criation.
In Settings>Point>Commands>Create Points> Edit Dialogue Box the
Labelling Prompt Method is set to Dialog
Point Style is set to Basic
Point Label is set to Basic
But When I insert a point the point style and point label are set to default and I have to manually set in the point proprieties the laber to basic.
How ca I set the point label automatically?
Thanks
In the Point Creation palette, set "Disable Description Keys" to TRUE. If "Disable Description Keys" is FALSE, then C3D will attempt to assign styles, as determined by your description keys. If it fails to match the description keys, it doesn't apply any styles, and your points use the styles from their top-level Point Group (usually the "_All Points" point group).
If you set "Disable Description Keys" to TRUE, then C3D will use the "Default Styles" from the Create Points dialog.
(It can be confusing that DescKey matching is disabled by setting that value to "True", but that's the way the C3D team designed it...)
