Well, In the attached drawing, Model space Object is 3D-Solid, wheres in paper space objects (front , side and top view) are lines and circles. and same lines and circles are showed up on Model space, whick looks clutter.
It does not happen in ProE or even in solid works.
I attached an image of the properties in model space. All of these elements exist in model space.
In each view port, there are layers frozen within the viewport (VP Freeze). If you unfreeze all of these, all of the elements in model space can then be seen in that view port and selected.
  • Replies 22
  • david1954
    11
  • DNK
    7
  • Dana W
    3
  • MSasu
    2
Posted Images
One more try, and that is it.
The views in paper space are views of the actual model space object from different viewing positions. The colors and detail can be manipulated through several different options avalable.
See ya.
