Can I "mirror" the text of an attribute??
  dbroada said:
looks like we might have to wait a little longer. :(
Like "waiting for 'The Eagles' to put out their last album" wait a little longer? :shock::lol:
  • Replies 28
  • DNK
    9
  • dbroada
    8
  • Ryder76
    6
  • tzframpton
    3
Posted Images
You can do so by inserting a nested block, then exploding it down one level so that a single 'free floating' text element references the attributed block.
Huh? :? :? :?
  Ryder76 said:
Huh? :? :? :?
Insert the attached block.
Explode.
Edit the attributed block (bottom right number + rectangle)
Refresh and the text element in the top left will update.
BLOCK2.dwgFetching info...
but isn't that where we were several posts back. Two independent entities that are texturally linked but no longer part of a block?
It can be inserted into a drawing so that you only type the attribute once and the text will update.
You can not get a block to reference values within itself, but this can be used over and over again from drawing to drawing, and multiple times within the same drawing.
which is what I was trying to say two days ago. ;)
  • 8 years later...
I am attempting to make a block for elevations for four possible potions but only want 1 set of attributes. I've tried the field suggestion from earlier in this post with no luck.
TIA
