save grading criteria sets
What is the procedure to save grading criteria sets created in one drawing for future use in another?
It is best to create your criteria sets in your standard template drawing.
If you need to transfer criteria sets from one .dwg to another you will have to create a named criteria set in the new .dwg and then click/drag the criteria from the old drawing into this new criteria set within the toolspace > settings > master view.
