On 10/20/2022 at 5:44 AM, BIGAL said:
Post a dwg not sure what your after.
Dear BIGAL,
Attached drawing for reference.
TEST-SPOT-01.dwg
Edited by CADWORKER
  • Replies 21
  • alanjt
    9
  • sadhu
    7
  • asos2000
    2
  • CADWORKER
    2
Posted Images
Try this
; Adds a fixed amount to a number
(Alert "TO USE JUST TYPE A2L or A2LM for multiple ")
;(setvar "cmdecho" 1)
(setq olddimzin (getvar "Dimzin"))
(setvar "dimzin" 0)
(DEFUN c:A2L ( / test en1 v1 a b el en1)
(setq v2 (getreal "\nEnter amount"))
(setq test 1)
(while (= test 1)
      (setq en1 (car (entsel "\nSelect text number:" )))
       (if (/= en1 nil)
        (setq el1 (entget en1))
        (setq v1 (atof (cdr (assoc 1 el1))))
        (setq a (+ v1 v2))
        (setq b (rtos a 2 0))
        (setq el (subst (cons 1 b) (assoc 1 el1) el1))
        (entmod el)
;        (entupd en1)
        );progn
       (princ "\nplease pick again"); else
     );if
); while true
(setq el nil)
(setq en nil)
(setq a nil)
(setq v1 nil)
(setvar "dimzin" olddimzin)
); END a2l DEFUN
(defun c:A2LM ()
(if (not AH:getvalsm)(load "Multi Getvals"))
(setq ss (ssget (list (cons 0 "Text"))))
(setq len (sslength ss))
(setq x 0)
(repeat len
(setq en1 (ssname ss x))
        (setq a (+ v1 v2))
        (entmod el)
(setq x (+ x 1))
); repeat
(setq el nil
      ss nil)
(setq en nil)
(setq a nil)
(setq v1 nil)
); END a2lm DEFUN
