When i try to select an object, and clearly it's only one object, the proximity of another object, makes this box appears..
Conclusion...i have to click twice for one pick....
I've tried searching for the removal possibility, without result..
Also, it appeared all of a sudden, yesterday.. probably a shortcut.
Thank you for any help.
You toggle it off with the SC button at the bottom of the screen.
Also right click on it, pick settings to see your options. If you like the old way of selection cycling you can turn the box off and use the old style. I like the new box but only turn it on when I think it is needed.
