fahim108 Posted May 12, 2010 Posted May 12, 2010 Holy cow, my options menu is showing some strange artifacts lately, as you can see in the attached image... Icons Everywhere! Any guesses? I suppose it has something to do with my VGA driver, or maybe not! *Images re-attached. Quote
viviancarvalho Posted May 12, 2010 Posted May 12, 2010 The images you attached are not visible. Quote
viviancarvalho Posted May 12, 2010 Posted May 12, 2010 Sorry buddy. I never came across such a problem anytime. But i think this has something to do with the screen resolution or the graphics card. Quote
ReMark Posted May 12, 2010 Posted May 12, 2010 You changed your icons to display at a larger size dude! Those same icons are always there. Quote
ReMark Posted May 12, 2010 Posted May 12, 2010 Minimize your programs. Right-click on an empty part of your desktop. In the pop-up window that appears select Properties. In the Display Properties window click on the Appearance tab. In the next window click on the Effects button (lower right hand corner). Uncheck the box labeled Use large icons. Click the OK button. Click the OK button on the remaining window. Done. Quote
fahim108 Posted May 12, 2010 Author Posted May 12, 2010 You changed your icons to display at a larger size dude! Those same icons are always there. Hehe! ...I just tried your suggestion but found "Windows 2000 Vista Patch" (a stupid skinning utility) to be the real culprit, uninstalled it and everything was fine. But since Win2k UI sucks, I'm planning to reinstall it again... Who cares for a couple of monster icons... lolz! Quote
