Lee Mac Posted May 10, 2010 Posted May 10, 2010 Thanks Buzzard, Yeah, the function for set-tile was to aid in the error checking, for cases such that the list has length 3, but the global points to item 4... As you guessed, the globals are those with asterisks Oh, and I only used a single VL function (vl-prin1-to-string), just to aid in writing the action_tile statements, (makes things easier to read in the VLIDE). If you have any questions, or find any quirks, let me know. Lee Quote
The Buzzard Posted May 10, 2010 Author Posted May 10, 2010 Again Thank You, Just tested it, And so far so good. I experimented with the dialog over the weekend and it looks great. My first thought with list boxes in the dialog was that it would look shabby, But it turned out for the better. Also it seems to simplify the selection process much better than radio buttons. Here is what I have done with it. Quote
Lee Mac Posted May 10, 2010 Posted May 10, 2010 I do find with list_box's that the selection is clearer, as all options are open for the user to see. Glad I could be of help. Quote
The Buzzard Posted May 10, 2010 Author Posted May 10, 2010 I do find with list_box's that the selection is clearer, as all options are open for the user to see. Glad I could be of help. Out of curiosity, What was the original error problem? I did notice that the action tiles were written in series and depended upon the first tile although I am not sure if that had anything to do with it. What I do know is the remedy that I cooked up was in no way a solution to the problem. When I checked variables at the command prompt, They all seem to have the correct values. I was a bit puzzled after that. Quote
Lee Mac Posted May 10, 2010 Posted May 10, 2010 It was quite a simple fix actually - the 'Models' variable did not hold a value until the first tile was selected. But I felt it better to rewrite the whole program so that I could include some better trapping. Quote
The Buzzard Posted May 10, 2010 Author Posted May 10, 2010 It was quite a simple fix actually - the 'Models' variable did not hold a value until the first tile was selected. But I felt it better to rewrite the whole program so that I could include some better trapping. So what I did was give it a constant value by setting the tile I suppose. Even if I could not get the old method to save previous values, That sure would not have helped much. Quote
lfe011969 Posted August 5, 2010 Posted August 5, 2010 Buzzard, Have fun playing around with this one Lee, I had to when I ran your example and was told I couldn't afford my selection. You mean I'm not the only CAD monkey who doesn't make that much money? BTW, I came across this thread as I am researching DCL / Lisp relationships as they apply to multiple list boxes. Your code has given me good insight so thanks. Below is my failed attempt at trying to do it on my own (with minimal help and a book I got and a Lisp command guide Alan shared with me). I was thinking the only way I'm really going to learn to write code in Lisp is to sit down and do it and not just copy other people's code, but it's very difficult to say the least. So I'm back trying to look at other code examples and trying to learn what it means and then trying to adapt it to my own needs. (defun c:notes (/ dcl_id folderlist fname fIndex fSel notelist nname nIndex nSel) (setq dcl_id (load_dialog "notes.dcl")) (if (not (new_dialog "notes" dcl_id)) (progn (alert "The notes.dcl file could not be loaded!") (exit) ) ) (setq folderlist (list "Electrical" "General" "Outfitting" "Piping" "Removal" "Structure" "Test" ) ) (start_list "folderlist" 3) (mapcar 'add_list folderList) (end_list) (action_tile "cancel" "(cancelNotes)(done_dialog)") (action_tile "accept" "(insertNotes)") (action_tile "createbut" "(createNewNote)") (action_tile "addbut" "(addNoteToList)") (action_tile "subbut" "(subNoteFromList)") (start_dialog) (unload_dialog dcl_id) (setq fname (get_tile "folderlist")) (if (/= fname "") (progn (cond (= fname "Electrical") ( (setq noteslist (list "E01" "E02" "E03") ) (start_list "noteslist" 3) (mapcar 'add_list notesList) (end_list) (setq nname (get_tile "noteslist")) (if (/= nname "") (progn (setq nIndex (atoi nname)) (setq nSel (nth nIndex noteslist)) ) (progn (setq nIndex -1) (setq nSel nil) ) ) ) (= fname "General") ( (setq noteslist (list "G01" "G02" "G03" "G04") ) (start_list "noteslist" 3) (mapcar 'add_list notesList) (end_list) (setq nname (get_tile "noteslist")) (if (/= nname "") (progn (setq nIndex (atoi nname)) (setq nSel (nth nIndex noteslist)) ) (progn (setq nIndex -1) (setq nSel nil) ) )) (= fname "Outfitting") ((setq noteslist (list "O01") ) (start_list "noteslist" 3) (mapcar 'add_list notesList) (end_list) (setq nname (get_tile "noteslist")) (if (/= nname "") (progn (setq nIndex (atoi nname)) (setq nSel (nth nIndex noteslist)) ) (progn (setq nIndex -1) (setq nSel nil) ) )) (= fname "Piping") ((setq noteslist (list "P01" "P02" "P03" "P04" "P05" "P06" "P07") ) (start_list "noteslist" 3) (mapcar 'add_list notesList) (end_list) (setq nname (get_tile "noteslist")) (if (/= nname "") (progn (setq nIndex (atoi nname)) (setq nSel (nth nIndex noteslist)) ) (progn (setq nIndex -1) (setq nSel nil) ) )) (= fname "Removal") ((setq noteslist (list "R01") ) (start_list "noteslist" 3) (mapcar 'add_list notesList) (end_list) (setq nname (get_tile "noteslist")) (if (/= nname "") (progn (setq nIndex (atoi nname)) (setq nSel (nth nIndex noteslist)) ) (progn (setq nIndex -1) (setq nSel nil) ) )) (= fname "Structure") ((setq noteslist (list "S01" "S02" "S03") ) (start_list "noteslist" 3) (mapcar 'add_list notesList) (end_list) (setq nname (get_tile "noteslist")) (if (/= nname "") (progn (setq nIndex (atoi nname)) (setq nSel (nth nIndex noteslist)) ) (progn (setq nIndex -1) (setq nSel nil) ) )) (= fname "Test") ((setq noteslist (list "T01") ) (start_list "noteslist" 3) (mapcar 'add_list notesList) (end_list) (setq nname (get_tile "noteslist")) (if (/= nname "") (progn (setq nIndex (atoi nname)) (setq nSel (nth nIndex noteslist)) ) (progn (setq nIndex -1) (setq nSel nil) ) )) ) (setq fIndex (atoi fname)) (setq fSel (nth fIndex folderlist)) ) (progn (setq fIndex -1) (setq fSel nil) ) ) ) (defun cancelNotes () (princ "\n\n ...Notes Manager cancelled. \n") ) (defun insertNotes () (alert "Coming soon!") ) (defun createNewNote () (alert "Coming soon!") ) (defun addNoteToList () (alert "Coming soon!") ) (defun subNoteFromList () (alert "Coming soon!") ) BTW, I only wrote enough code to try and get the two list boxes to populate so that's why the rest is unfinished. Lonnie notes.dcl Quote
Lt Dan's legs Posted August 5, 2010 Posted August 5, 2010 I'm trying to create a view that would display a block Would I create a slide? If so, are there any good sites I can go to that will show me how to make one I'm pretty new to dcl section : dialog { label = "Section tag V1.0"; : row { : boxed_column { label = "View"; : image { key = "Img"; height = 10.0; fixed_height = true; width = 20.0; fixed_width = true; alignment = centered; color = -2; }} : boxed_radio_column { label = "Direction" ; : radio_button { key = "1" ; label = "Left" ; value = "1";} : radio_button { key = "2" ; label = "Right" ;} : radio_button { key = "3" ; label = "Up" ;} : radio_button { key = "4" ; label = "Down" ;}} } : boxed_column { label = "Label" ; : edit_box { label = "Tag Label: "; key = "tag"; mnemonic = "t"; edit_limit = 5; edit_width = 5; value = "A"; alignment = centered;} : paragraph {}} :row { : button { key = "accept"; label = "Insertion Point"; is_default = true; fixed_width = true;} : button { key = "cancel"; label = "Cancel"; is_default = false; fixed_width = true;} } } Quote
The Buzzard Posted August 5, 2010 Author Posted August 5, 2010 (edited) Lee, I had to when I ran your example and was told I couldn't afford my selection. You mean I'm not the only CAD monkey who doesn't make that much money? BTW, I came across this thread as I am researching DCL / Lisp relationships as they apply to multiple list boxes. Your code has given me good insight so thanks. Below is my failed attempt at trying to do it on my own (with minimal help and a book I got and a Lisp command guide Alan shared with me). I was thinking the only way I'm really going to learn to write code in Lisp is to sit down and do it and not just copy other people's code, but it's very difficult to say the least. So I'm back trying to look at other code examples and trying to learn what it means and then trying to adapt it to my own needs. (defun c:notes (/ dcl_id folderlist fname fIndex fSel notelist nname nIndex nSel) (setq dcl_id (load_dialog "notes.dcl")) (if (not (new_dialog "notes" dcl_id)) (progn (alert "The notes.dcl file could not be loaded!") (exit) ) ) (setq folderlist (list "Electrical" "General" "Outfitting" "Piping" "Removal" "Structure" "Test" ) ) (start_list "folderlist" 3) (mapcar 'add_list folderList) (end_list) (action_tile "cancel" "(cancelNotes)(done_dialog)") (action_tile "accept" "(insertNotes)") (action_tile "createbut" "(createNewNote)") (action_tile "addbut" "(addNoteToList)") (action_tile "subbut" "(subNoteFromList)") (start_dialog) (unload_dialog dcl_id) (setq fname (get_tile "folderlist")) (if (/= fname "") (progn (cond (= fname "Electrical") ( (setq noteslist (list "E01" "E02" "E03") ) (start_list "noteslist" 3) (mapcar 'add_list notesList) (end_list) (setq nname (get_tile "noteslist")) (if (/= nname "") (progn (setq nIndex (atoi nname)) (setq nSel (nth nIndex noteslist)) ) (progn (setq nIndex -1) (setq nSel nil) ) ) ) (= fname "General") ( (setq noteslist (list "G01" "G02" "G03" "G04") ) (start_list "noteslist" 3) (mapcar 'add_list notesList) (end_list) (setq nname (get_tile "noteslist")) (if (/= nname "") (progn (setq nIndex (atoi nname)) (setq nSel (nth nIndex noteslist)) ) (progn (setq nIndex -1) (setq nSel nil) ) )) (= fname "Outfitting") ((setq noteslist (list "O01") ) (start_list "noteslist" 3) (mapcar 'add_list notesList) (end_list) (setq nname (get_tile "noteslist")) (if (/= nname "") (progn (setq nIndex (atoi nname)) (setq nSel (nth nIndex noteslist)) ) (progn (setq nIndex -1) (setq nSel nil) ) )) (= fname "Piping") ((setq noteslist (list "P01" "P02" "P03" "P04" "P05" "P06" "P07") ) (start_list "noteslist" 3) (mapcar 'add_list notesList) (end_list) (setq nname (get_tile "noteslist")) (if (/= nname "") (progn (setq nIndex (atoi nname)) (setq nSel (nth nIndex noteslist)) ) (progn (setq nIndex -1) (setq nSel nil) ) )) (= fname "Removal") ((setq noteslist (list "R01") ) (start_list "noteslist" 3) (mapcar 'add_list notesList) (end_list) (setq nname (get_tile "noteslist")) (if (/= nname "") (progn (setq nIndex (atoi nname)) (setq nSel (nth nIndex noteslist)) ) (progn (setq nIndex -1) (setq nSel nil) ) )) (= fname "Structure") ((setq noteslist (list "S01" "S02" "S03") ) (start_list "noteslist" 3) (mapcar 'add_list notesList) (end_list) (setq nname (get_tile "noteslist")) (if (/= nname "") (progn (setq nIndex (atoi nname)) (setq nSel (nth nIndex noteslist)) ) (progn (setq nIndex -1) (setq nSel nil) ) )) (= fname "Test") ((setq noteslist (list "T01") ) (start_list "noteslist" 3) (mapcar 'add_list notesList) (end_list) (setq nname (get_tile "noteslist")) (if (/= nname "") (progn (setq nIndex (atoi nname)) (setq nSel (nth nIndex noteslist)) ) (progn (setq nIndex -1) (setq nSel nil) ) )) ) (setq fIndex (atoi fname)) (setq fSel (nth fIndex folderlist)) ) (progn (setq fIndex -1) (setq fSel nil) ) ) ) (defun cancelNotes () (princ "\n\n ...Notes Manager cancelled. \n") ) (defun insertNotes () (alert "Coming soon!") ) (defun createNewNote () (alert "Coming soon!") ) (defun addNoteToList () (alert "Coming soon!") ) (defun subNoteFromList () (alert "Coming soon!") ) BTW, I only wrote enough code to try and get the two list boxes to populate so that's why the rest is unfinished. Lonnie I'm trying to create a view that would display a block Would I create a slide? If so' date=' are there any good sites I can go to that will show me how to make one I'm pretty new to dcl section : dialog { label = "Section tag V1.0"; : row { : boxed_column { label = "View"; : image { key = "Img"; height = 10.0; fixed_height = true; width = 20.0; fixed_width = true; alignment = centered; color = -2; }} : boxed_radio_column { label = "Direction" ; : radio_button { key = "1" ; label = "Left" ; value = "1";} : radio_button { key = "2" ; label = "Right" ;} : radio_button { key = "3" ; label = "Up" ;} : radio_button { key = "4" ; label = "Down" ;}} } : boxed_column { label = "Label" ; : edit_box { label = "Tag Label: "; key = "tag"; mnemonic = "t"; edit_limit = 5; edit_width = 5; value = "A"; alignment = centered;} : paragraph {}} :row { : button { key = "accept"; label = "Insertion Point"; is_default = true; fixed_width = true;} : button { key = "cancel"; label = "Cancel"; is_default = false; fixed_width = true;} } } [/quote'] This is an old thread. You guys will get alot more better replys if you start a new thread on your subject. Edited August 5, 2010 by The Buzzard Quote
Bhull1985 Posted October 2, 2013 Posted October 2, 2013 Does anyone know how to do this who would be willing to answer some questions so that I may get past this portion ? Now I understand completely how office workers often would "go postal" This is so terribly frustrating. I don't know how to construct a list of data that will allow the $value callback to select the appropriate slide file for a preview box tacked on to what Lee created in this thread's earlier posts Quote
Bhull1985 Posted October 2, 2013 Posted October 2, 2013 Okay, I have received sufficient assistance in order to complete my task. Apologies for being impatient as I know I am. THANK YOU CAB!!!! Quote
