freemine Posted August 27, 2008 Posted August 27, 2008 Hi, I want to give sequential names to each points (example: z1-1200-001, z1-1200-002, z1-1200-003, ...each points will be like these). How can i do this. If you have any idea, please help me. Many thanks. Quote
rustysilo Posted August 27, 2008 Posted August 27, 2008 When you say "names" do you mean you want them numbered this way, ie you want the point numbers to be in that format as opposed to 1, 2, 3, etc.? There is a field you can add to your point label styles called "name", but I'm not too familiar with it. If you want your point numbers rather than this name field to be in the format you requested you can modify the point number in your label style, but I'm unsure of how to get the leading zeros (z1-1200-001) in the number itself. Quote
freemine Posted August 28, 2008 Author Posted August 28, 2008 When you click create points, create points dialog box will appear. And we can set it up like below; (**** changed) _________________________________________________________ *Default Layer Layer *Points Creation Local Coordinates: Easting - Northing Grid Coordinates Grid: Easting - Grid Northing Geographic Coordinates: Latitude - Longitude Prompt For Levels: Automatic Prompt For Point Names: Automatic ***** Prompt For Descriptions: None Default Level: 0.000' Default Description: Z1-example **** Match On Description Parameters: ($1, $2, etc.) false Disable Description Keys: true Echo Coordinates to Command Line: true *Default Styles Point Style: Standard Point Label Style :Standard *Default Name Format Point Group Name Template: Point Group - () Point Name Template: Z1-1305 - **** *Point Identity Next Point Number: 1 **** Use Sequential Numbering: true **** Point Number Offset: 1 **** Sequence Point Numbers From: 1 **** If Point Numbers Are Supplied Use Force Names: true If Point Numbers Already Exist: Notify If Point Names Already Exist: Notify If Point Numbers Need To Be Assigned: Use next point number Quote
