Are you using full AutoCAD 2006?
Have you been able to load the lisp routine?
This one displays this block name as it is being processed so to indicate that it is working.
(defun c:nestb2lay0 (/ tdef fe fd)
 (while (setq tdef (tblnext "BLOCK" (not tdef)))
        (and (/= (logand (cdr (assoc 70 tdef)) 4) 4)
             (princ (strcat "\n" (cdr (assoc 2 tdef))))
             (setq fe (cdr (assoc -2 tdef)))
             (while fe
                (setq fd (entget fe))
                (and (= "INSERT" (cdr (assoc 0 fd)))
                     (/= "0" (cdr (assoc 8 fd)))
                     (entmod (subst '(8 . "0") (assoc 8 fd) fd)))
                (setq fe (entnext fe)))))
 (prin1))
-David
  • Replies 23
  • ged
    11
  • chulse
    6
  • David Bethel
    3
  • Strix
    2
One more example:
(defun c:bzero()
 (vl-load-com)
 (vlax-for b(vla-get-Blocks
          (setq actDoc(vla-get-ActiveDocument
        (vlax-get-acad-object))))
   (vlax-for i b(vla-put-Layer i "0")))
 (vla-Regen actDoc acAllViewports)
); end of c:bzero
Step 1 :put Above Code In Note Pad
Step 2 :save As ***.lsp
Step 3 :explorer Drag And Drop Into Acad
Step 4 :type Bzero
