I am using the attached lisp for run the longitudinal sections.
in this Lisp i want to change the banking and cutting color. and i want to trim the excess horizontal line lines beyound the profile.
can u please anybody help me.
i am atacheing the lisp file and the data file to run the l-section and also attaching the required format jpg file pls help me.
lisp procedure
appload the lisp and command for the lisp is "LSC"
select the ".prn" file(i am attached that file as txt you can remove the .txt in the attachement)
u can enter the datam value is -360
horizontal scale is -0.2 and vertical scale is 2
Jakeer
New L-sec_0.622.lsp
3 lsc of 699.prn.txt
  • 2 years later...
Its really amazing can any one suggest
  • 11 months later...
If you have excel file for cutting and filling than upload it. than it is possible to create the lisp as you want. I can help you with read excel data from file and meet your requirements.
  • 1 year later...
hi jakeerbasha nice job with this lisp. I am trying to find a lisp drawing x sections from files . Look the attach photo and the comments in the code.I attach 2 data files for ground 1 and ground 2
;xsection form file data
(defun c:xsection( / fn fp lst l p1 p2 oldOSM )
 (COMMAND "_layer" "_m" "ground1" "_c" "8" "" "")
 (COMMAND "_layer" "_m" "ground2" "_c" "3" "" "")
; if we have a 2d ground line
 (COMMAND "_layer" "_m" "text_ground1" "_c" "8" "" "")
 (COMMAND "_layer" "_m" "text_ground2" "_c" "3" "" "")
 (COMMAND "_layer" "_m" "name of section" "_c" "1" "" "")
 (COMMAND "_layer" "_m" "datum" "_c" "1" "" "")
 (COMMAND "_layer" "_m" "scale" "_c" "1" "" "")
 (COMMAND "_layer" "_m" "Vertical lines" "_c" "140" "" "")
 (COMMAND "_layer" "_m" "Vertical yellow line" "_c" "2" "" "")
(setq ns (getreal  "\n give name of the section : "))
(setq dtm (getreal  "\n give datum elevetion : "))
(setq scl(/ (getreal  "\n give scale  (100,200,500,etc) : ") 100))
(setq ht(* 0.175 scl))
(setq fn (getfiled "Select ASCII file for ground 1" "" "txt" 4))
; I want to add a command when i whant in second time to add ground 2
;ask me.Do you have another ground line (Y/N)
;When i answer  Yes then load ASCII file for ground 2
;(setq fe (getfiled "Select ASCII file for ground 2" "" "txt" 4))
;And ask me to pick the inset point for the ground 2 like the photo
;Look the photo to see the insert point of ground 2
 (setq fp (open fn "r") lst '())
 (while (setq l (read-line fp))
   (setq lst (cons l lst))
 (close fp)
 (setq lst (reverse lst))
 (setq oldOSM (getvar "osmode"))
 (setvar "osmode" 0)
 (command "._pline" "")
 (foreach item lst
  (if (/= item "")
   (command item)
   (command "" "._pline")
 (command "")
(setvar "osmode" oldOSM)
;write data to the table .(I need help for this)
Can you update your code to help me ?
Thanks
ground1.txt
ground2.txt
  • 4 months later...
Given your number of posts sounds like its time you started to have a go at doing the code rather than asking for freebies.
The answer to your actual qauestion is easy make the line drawing part a defun. Then you can run it for as many surfaces as you like just offset the text lines down, datum stays where it is.
  • 1 month later...
its good.but works only with ur file.kindly guide me how to make a pnr file from data sheet containing chainage, ground level and formation level.
